Hi Mr. Mikko, I have make a little progress with my meters. I have find the cipher codes, when I try to connect with High level security I receive error ''service error initiate error exception. Initiate DLMS version too low''.
I will upload the communication .
23:20:27 11:20:27.945 Info Opening
23:20:27 11:20:27.960 Info Ρυθμίσεις σειριακής θύρας: Όνομα θύρας: COM3 Ποσοστό Baud: 300 Κομμάτια δεδομένων: 7 Ισοτιμία: Even Διακοπή Bits: One Έλεγχος ροής: None Eop: None
23:20:27 11:20:27.976 Info Open
23:20:28 11:20:28.997 Sent 2F 3F 21 0D 0A
23:20:29 11:20:29.485 Received 2F
23:20:29 11:20:29.501 Received 2F
23:20:29 11:20:29.554 Received 48
23:20:29 11:20:29.586 Received 58
23:20:29 11:20:29.617 Received 45
23:20:29 11:20:29.655 Received 35
23:20:29 11:20:29.686 Received 5C
23:20:29 11:20:29.717 Received 35
23:20:29 11:20:29.739 Received 48
23:20:29 11:20:29.771 Received 58
23:20:29 11:20:29.802 Received 45
23:20:29 11:20:29.840 Received 33
23:20:29 11:20:29.871 Received 31
23:20:29 11:20:29.918 Received 30
23:20:29 11:20:29.956 Received 0D
23:20:29 11:20:29.956 Sent 06 32 35 32 0D 0A
23:20:31 11:20:31.960 Info Closing
23:20:32 11:20:32.091 Info Closed
23:20:32 11:20:32.091 Info Opening
23:20:32 11:20:32.091 Info Ρυθμίσεις σειριακής θύρας: Όνομα θύρας: COM3 Ποσοστό Baud: 9600 Κομμάτια δεδομένων: 8 Ισοτιμία: None Διακοπή Bits: One Έλεγχος ροής: None Eop: None
23:20:32 11:20:32.098 Info Open
23:20:33 Send SNRM request.
23:20:33 11:20:33.148 Sent 7E A0 07 03 21 93 0F 01 7E
23:20:33 11:20:33.464 Received 7E A0
23:20:33 11:20:33.480 Received A0 1E 21 03 73 C3 7A 81 80 12 05 01 80
23:20:33 11:20:33.502 Received 01 80 07 04 00 00 00 01 08 04 00 00 00 01
23:20:33 11:20:33.518 Received 53 3B
23:20:33
23:20:33 Send AARQ request.
23:20:33 11:20:33.602 Sent 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 62 1E 5D FF FF 88 55 7E
23:20:33 11:20:33.803 Received 7E A0 37 21 03 30 6C
23:20:33 11:20:33.818 Received 6C 7C E6 E7 00 61 29 A1
23:20:33 11:20:33.834 Received 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02
23:20:33 11:20:33.850 Received 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00
23:20:33 11:20:33.865 Received 10 10 00 7D 00 07 7D EE
23:20:33
RX: 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 10 00 7D 00 07 7D EE 7E
23:20:33 11:20:33.934 Sent 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 81 00 01 00 00 2B 01 00 FF 02 00 78 42 7E
23:20:38 Data send failed. Try to resend 1/3
23:20:38 11:20:38.949 Sent 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 81 00 01 00 00 2B 01 00 FF 02 00 78 42 7E
23:20:39 11:20:39.219 Received 7E A0 07 21 03 51 11 42 7E
23:20:39
RX: 7E A0 07 21 03 51 11 42 7E
23:20:39 Disconnect request
23:20:39 11:20:39.234 Sent 7E A0 07 03 21 53 03 C7 7E
23:20:39 11:20:39.450 Received 7E A0 07
23:20:39 11:20:39.466 Received 07 21 03 73
23:20:39
RX: 7E A0 07 21 03 73 01 40 7E
23:20:39 11:20:39.466 Info Closing
23:20:39 11:20:39.598 Info Closed
23:20:39 11:20:39.598 Info Opening
23:20:39 11:20:39.598 Info Ρυθμίσεις σειριακής θύρας: Όνομα θύρας: COM3 Ποσοστό Baud: 300 Κομμάτια δεδομένων: 7 Ισοτιμία: Even Διακοπή Bits: One Έλεγχος ροής: None Eop: None
23:20:40 11:20:40.617 Sent 2F 3F 21 0D 0A
23:20:40 11:20:40.971 Received 2F
23:20:41 11:20:41.002 Received 2F
23:20:41 11:20:41.040 Received 48
23:20:41 11:20:41.071 Received 58
23:20:41 11:20:41.102 Received 45
23:20:41 11:20:41.125 Received 35
23:20:41 11:20:41.171 Received 5C
23:20:41 11:20:41.203 Received 35
23:20:41 11:20:41.241 Received 48
23:20:41 11:20:41.272 Received 58
23:20:41 11:20:41.303 Received 45
23:20:41 11:20:41.340 Received 33
23:20:41 11:20:41.372 Received 31
23:20:41 11:20:41.403 Received 30
23:20:41 11:20:41.441 Received 0D
23:20:41 11:20:41.441 Sent 06 32 35 32 0D 0A
23:20:43 11:20:43.447 Info Closing
23:20:43 11:20:43.563 Info Closed
23:20:43 11:20:43.563 Info Opening
23:20:43 11:20:43.563 Info Ρυθμίσεις σειριακής θύρας: Όνομα θύρας: COM3 Ποσοστό Baud: 9600 Κομμάτια δεδομένων: 8 Ισοτιμία: None Διακοπή Bits: One Έλεγχος ροής: None Eop: None
23:20:44 Send SNRM request.
TX: 7E A0 07 03 03 93 8C 11 7E
23:20:44 11:20:44.582 Sent 7E A0 07 03 03 93 8C 11 7E
23:20:44 11:20:44.767 Received 7E A0 1E 03 03 73 40 CC 81 80 12
23:20:44 11:20:44.783 Received 12 05 01 80
23:20:44 11:20:44.799 Received 04 00 00 00 01 53 3B
23:20:44
RX: 7E A0 1E 03 03 73 40 CC 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
23:20:44 Send AARQ request.
TX: 7E A0 7C 03 03 10 4F 3D E6 E6 00 60 6E A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 48 58 45 32 33 39 32 38 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 67 78 1B 37 3B 53 3C 17 53 0C 2D 22 55 69 1B 28 BE 34 04 32 21 30 30 00 00 00 01 BE 12 7D E5 9F F3 94 59 C9 16 D9 01 30 EB 92 ED 03 5A E7 E3 65 E8 F2 F6 41 63 E5 12 00 D6 05 17 6E F2 7B 4A AA 73 2F EF F6 E3 2C 98 36 7E
23:20:44 11:20:44.836 Sent 7E A0 7C 03 03 10 4F 3D E6 E6 00 60 6E A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 48 58 45 32 33 39 32 38 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 67 78 1B 37 3B 53 3C 17 53 0C 2D 22 55 69 1B 28 BE 34 04 32 21 30 30 00 00 00 01 BE 12 7D E5 9F F3 94 59 C9 16 D9 01 30 EB 92 ED 03 5A E7 E3 65 E8 F2 F6 41 63 E5 12 00 D6 05 17 6E F2 7B 4A AA 73 2F EF F6 E3 2C 98 36 7E
23:20:45 11:20:45.238 Received 7E A0
23:20:45 11:20:45.253 Received A0 5A 03 03 30 84 D8 E6 E7 00 61 4C A1
23:20:45 11:20:45.269 Received 06 07 60 85 74 05 08 01 03 A2 03 02 01 01
23:20:45 11:20:45.285 Received A3 05 A1 03 02 01 01 A4 0A 04 08 48 58 45
23:20:45 11:20:45.300 Received 03 31 6D 1E 77 88 02 07 80 89 07 60 85 74
23:20:45 11:20:45.316 Received 05 08 02 02 AA 12 80 10 EE 4E 03 C4 DB DF AB
23:20:45 11:20:45.338 Received 2D 5F B6 8C 7B A2 1F 68 80 BE 06 04 04 0E
23:20:45 11:20:45.354 Received 01 06 01 32 8C
23:20:45
RX: 7E A0 5A 03 03 30 84 D8 E6 E7 00 61 4C A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 01 A4 0A 04 08 48 58 45 03 31 6D 1E 77 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 12 80 10 EE 4E 03 C4 DB DF AB 2D 5F B6 8C 7B A2 1F 68 80 BE 06 04 04 0E 01 06 01 32 8C 7E
23:20:45 11:20:45.369 Sent 7E A0 07 03 03 53 80 D7 7E
23:20:45 11:20:45.539 Received 7E A0 07 03 03
23:20:45 11:20:45.554 Received 03 73 82 F6
23:20:45
RX: 7E A0 07 03 03 73 82 F6 7E
23:20:45 11:20:45.570 Sent 01 42 30 03 0D 0A
23:20:50 11:20:50.570 Info Closing
23:20:50 11:20:50.686 Info Closed
where is the wrong ?? I must change the setting of ''secured connction''??
Regards Lambros
Hi, Select supported…
Select supported services. Un-check "Delta value encoding". Try to connect again.
I believe this is causing problems with your meter.
