  2. IP6Setup Reading Error
By Jimmy, 30 May, 2024
Hi, Mikko,
I read IP6 Setup from an Indian Standard meter.
10:20:59 Read object type Ip6Setup index: 7
7E A0 2C 03 61 FE CC B0 E6 E6 00 C8 1E 30 00 00 1D 39 40 46 05 42 32 91 84 69 0E 0E AD 73 4B 81 56 54 75 C7 E9 97 31 16 38 08 D0 BF 22 7E
10:20:59
7E A0 4C 61 03 1E 36 28 E6 E7 00 CC 3E 30 00 00 18 03 25 3F 74 0B EE 2E B2 0C 6B 44 68 09 BB 82 C7 EE F3 EE E1 9E 4A 65 EF EE BD 49 F3 D5 CE ED 3D 20 C2 4D 4D 03 32 0D 64 FE 44 AF 30 1B 8D A6 05 E9 B1 AF 2C D0 EF CB 5D EA 62 20 F1 7E
System.ArgumentException: An Invalid IP address was specified.
Parameter Name: address
在 System.Net.IPAddress..ctor(Byte[] address)
在 Gurux.DLMS.Objects.GXDLMSIp6Setup.Gurux.DLMS.Objects.IGXDLMSBase.SetValue(GXDLMSSettings settings, ValueEventArgs e)
在 Gurux.DLMS.GXDLMSClient.UpdateValue(GXDLMSObject target, Int32 attributeIndex, Object value, List`1 columns)
在 Gurux.DLMS.GXDLMSClient.UpdateValue(GXDLMSObject target, Int32 attributeIndex, Object value)
在 GXDLMSDirector.GXDLMSCommunicator.Read(Object sender, GXDLMSObject obj, Boolean forceRead)
在 GXDLMSDirector.MainForm.Read(Object sender, GXAsyncWork work, Object[] parameters)
The Parsed content is as image shows.
But GXDLMSDirector could not give a normal content display which says "An Invalid IP address was specified."
Best Regards,
Jimmy Lau
1 year ago
Hi, Please, don't add…
Please, don't add pictures. They are hard to read and plain text is better.
Your IP address is not a valid IPv6 address: 2100:0000:0000:0000:0000:0000:0000:00001
You need to fix it and use the correct IPv6 address.
Jimmy
1 year ago
Thanks, now I know what it…
Thanks, now I know what it does mean as an prompt message from this unspecified IPv6 address.
Jimmy Lau
  • Wed, 06/04/2025 - 13:35
    gurux.dlms.c 9.0.2506.0401
  • Fri, 05/30/2025 - 08:30
    gurux.dlms.c 9.0.2505.3001
  • Tue, 05/27/2025 - 08:10
    Gurux.Serial.Android 2.0.12
  • Mon, 05/26/2025 - 08:39
    gurux.dlms.c 9.0.2505.2601
  • Tue, 05/20/2025 - 08:40
    gurux.dlms.c 9.0.2505.2001
  • Error while reading event log object
  • GXDLMS Simulator – AssociationLogicalName Not Listed
  • Failed to read meter through raspberry pi 5 and probe
  • Protocol Version in AARQ Packet
  • Problem with reading energymeter iskraemeco MT880
