  2. Kamstrup Single Phase Omnipower- Invalid Block Number
Kamstrup Single Phase Omnipower- Invalid Block number
By craig-gxe, 28 May, 2024
Hi I am connecting to and interfacing with Kamstrup Omnipower electricity meters. Using the module port association on the Gurux dlms director, I use the following settings:
Client Address=18
Physical Address=16
HDLC with max transmit and receive size to 1010
The connection is Serial at 9600 baud rate
The authentication is Low with password 12345.
When I connect to an omnipower three phase CT meter, I am able to connect successfully to the meter and read the logged data. However, when I connect using the same settings but for the single phase meter, then I get the error "GetObjects failed. Invalid Block number. It is 26 and it should be 27."
Please provide some guidance as to what is different and what I can do. I understand that the single phase meter will have fewer parameters to log but is this the reason for Gurux not connecting?
11 months 3 weeks ago
Hi, If I remember right you…
If I remember right you need to use HDLC with max transmit and receive size 512 with some meters. The correct value is on the Omnipower documentation. Try to change size 1010 to 512 and try to read again.
craig-gxe
We tried adjusting the frame…
We tried adjusting the frame size and it did not produce a different result. It just caused an error with the HDLC which confirms that the 1010 framesize is the correct one to use.
Additionally when we tested, we can fetch the time from the Kamstrup Omnipower Single phase meter, so we are able to access certain the publically available date. However, when we try to access the profile generics (using low level security authentication) then we get the invalid block number error.
11 months 2 weeks ago
Hi, I checked that we have…
I checked that we have multiple meters from Kamstrup, but not one phase Omnipower so I can't test your problem.
I tested this with a three-phase meter and it worked without problems.
The problem is that the meter is returning an invalid block number. There should be block number 26, but the meter returns block 27. I believe that this is just a invalid block number if you are receiving the same issue every time and no blocks are missed.
You need to ask the meter vendor if there is a meter firmware update available that fixes this.
craig-gxe
Hi, So we are in the process…
So we are in the process of checking with Kamstrup for support on this matter. The support agent asked us to share the hex logs of the connection to help in deducing the potential issue.
Please let us know if you are able to gauge anything from the logs Mikko. I am not good with hex or the director, but the logs show it connecting successfully, communicating and receiving data from the meter. However, after a couple data blocks, suddenly there is not success. If you are able to deduce anything from this please let us know. We will also communicate any findings from our side, thanks:
07:33:22 Get Next Data block.
07:33:22 Read object type AssociationLogicalName index: 2
7E A0 13 21 25 32 22 D5 E6 E6 00 C0 02 C1 00 00 00 08 90 23 7E
07:33:23
7E A3 DE 25 21 52 BF 1F E6 E7 00 C4 02 C1 00 00 00 00 09 00 82 03 C6 02 04 12 00 03 11 00 09 06 01 01 60 32 04 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 0E 19 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 0D 19 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 21 19 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 1F 18 7C FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 20 18 7C FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 1F 18 80 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 20 18 80 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 60 39 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 60 39 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 60 39 03 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 60 39 04 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 20 19 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 1F 19 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 15 19 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 16 19 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 17 19 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 18 19 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 1D 19 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 1E 19 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 01 19 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 01 02 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 02 19 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 35 8D 7E
07:33:23 Get Next Data block.
07:33:23 Read object type AssociationLogicalName index: 2
7E A0 13 21 25 54 12 D3 E6 E6 00 C0 02 C1 00 00 00 09 19 32 7E
07:33:29 Data send failed. Try to resend 1/3
07:33:30
7E AB F0 25 21 64 3B 30 E6 E7 00 C4 02 C1 00 00 00 00 0A 00 82 03 DB 02 04 12 00 03 11 00 09 06 01 01 02 02 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 03 19 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 03 02 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 04 19 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 04 02 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 01 02 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 01 02 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 60 33 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 09 19 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 0A 19 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 02 02 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 02 02 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 01 0F 19 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 20 03 80 FF 02 02 01 06 02 03 0F 00 16 01 00 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 20 06 81 FF 02 02 01 06 02 03 0F 00 16 01 00 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 1F 03 80 FF 02 02 01 06 02 03 0F 00 16 01 00 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 1F 06 80 FF 02 02 01 06 02 03 0F 00 16 01 00 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 15 03 80 FF 02 02 01 06 02 03 0F 00 16 01 00 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 15 06 80 FF 02 02 01 06 02 03 0F 00 16 01 00 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 1D 03 80 FF 02 02 01 06 02 03 0F 00 16 01 00 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 94 90 7E 7E A0 07 25 21 71 F1 10 7E
07:33:30 Get Next Data block.
07:33:30 Read object type AssociationLogicalName index: 2
7E A0 13 21 25 76 02 D1 E6 E6 00 C0 02 C1 00 00 00 0A 82 00 7E
07:33:36 Data send failed. Try to resend 1/3
07:33:36
7E A3 C9 25 21 96 17 0B E6 E7 00 C4 02 C1 00 00 00 00 0B 00 82 03 B1 02 04 12 00 04 11 00 09 06 01 01 1D 06 80 FF 02 02 01 06 02 03 0F 00 16 01 00 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 20 03 82 FF 02 02 01 06 02 03 0F 00 16 01 00 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 20 06 83 FF 02 02 01 06 02 03 0F 00 16 01 00 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 82 00 04 FF 02 02 01 06 02 03 0F 00 16 01 00 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 01 06 01 FF 02 02 01 06 02 03 0F 00 16 01 00 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 01 06 02 FF 02 02 01 06 02 03 0F 00 16 01 00 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 01 06 03 FF 02 02 01 06 02 03 0F 00 16 01 00 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 01 06 04 FF 02 02 01 06 02 03 0F 00 16 01 00 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 01 06 05 FF 02 02 01 06 02 03 0F 00 16 01 00 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 01 06 06 FF 02 02 01 06 02 03 0F 00 16 01 00 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 01 06 07 FF 02 02 01 06 02 03 0F 00 16 01 00 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 01 06 08 FF 02 02 01 06 02 03 0F 00 16 01 00 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 02 06 01 FF 02 02 01 06 02 03 0F 00 16 01 00 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 02 06 02 FF 02 02 01 06 02 03 0F 00 16 01 00 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 01 02 06 03 FF 02 02 01 06 02 03 0F 00 16 01 00 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 D5 02 7E 7E A0 07 25 21 91 FF F7 7E
11 months ago
Hi, I hope that I finally…
I hope that I finally have an answer for this.
Select "Advanced" tab and change MAX PDU size from 65535 to 1007.
The meter returns Max PDU size to 2027, but it can't handle it.
After you change Max PDU size you can read the association view from your meter.
craig-gxe
9 months 2 weeks ago
Hi Mikko, we were able to…
Hi Mikko, we were able to get help from Kamstrup on this matter. They pointed out that the issue was on their side with the way they programmed the DLMS Server on their single phase meters. It was not compatible with Gurux. They then gave us new firmware to try out but we now have a different error. The dlms director reads the association view and as it is reading, it gets to the end and then gives an error: "Access Error: Device Reports temporary failure"
From the logs it seems to be reading and reading and then just gives that error:
14:39:49 Read object type ActivityCalendar index: 9
7E A0 19 21 25 DC FC 07 E6 E6 00 C0 01 C1 00 14 00 02 0D 00 00 FF 09 00 3C 47 7E
14:39:50
7E A0 12 25 21 FC EA E2 E6 E7 00 C4 01 C1 00 01 00 8A D8 7E
Duration: 94
14:39:50 Read object type ActivityCalendar index: 10
7E A0 19 21 25 FE EC 05 E6 E6 00 C0 01 C1 00 14 00 02 0D 00 00 FF 0A 00 54 6D 7E
14:39:50
7E A0 1E 25 21 1E C2 B1 E6 E7 00 C4 01 C1 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 1B 31 7E
Duration: 78
14:39:50 Read object type ScriptTable index: 2
7E A0 19 21 25 10 9C 0B E6 E6 00 C0 01 C1 00 09 00 00 0A 00 64 FF 02 00 B0 91 7E
14:39:50
7E A0 E2 25 21 30 A1 99 E6 E7 00 C4 01 C1 00 01 08 02 02 12 00 01 01 01 02 05 16 01 12 00 01 09 06 01 01 81 00 00 FF 0F 02 11 01 02 02 12 00 02 01 01 02 05 16 01 12 00 01 09 06 01 01 81 00 00 FF 0F 02 11 02 02 02 12 00 03 01 01 02 05 16 01 12 00 01 09 06 01 01 81 00 00 FF 0F 02 11 03 02 02 12 00 04 01 01 02 05 16 01 12 00 01 09 06 01 01 81 00 00 FF 0F 02 11 04 02 02 12 00 05 01 01 02 05 16 01 12 00 01 09 06 01 01 81 00 00 FF 0F 02 11 05 02 02 12 00 06 01 01 02 05 16 01 12 00 01 09 06 01 01 81 00 00 FF 0F 02 11 06 02 02 12 00 07 01 01 02 05 16 01 12 00 01 09 06 01 01 81 00 00 FF 0F 02 11 07 02 02 12 00 08 01 01 02 05 16 01 12 00 01 09 06 01 01 81 00 00 FF 0F 02 11 08 33 AC 7E
Duration: 282
7E A0 19 21 25 32 8C 09 E6 E6 00 C0 01 C1 00 09 00 01 0A 00 6A FF 02 00 27 A0 7E
14:39:50
7E A0 46 25 21 52 64 09 E6 E7 00 C4 01 C1 00 01 02 02 02 12 00 01 01 01 02 05 16 01 12 00 46 09 06 00 01 60 03 0A FF 0F 03 11 02 02 02 12 00 02 01 01 02 05 16 01 12 00 46 09 06 00 01 60 03 0A FF 0F 03 11 01 DD 11 7E
Duration: 109
7E A0 19 21 25 54 BC 0F E6 E6 00 C0 01 C1 00 09 00 02 0A 00 6A FF 02 00 49 08 7E
14:39:50
7E A0 46 25 21 74 50 4D E6 E7 00 C4 01 C1 00 01 02 02 02 12 00 01 01 01 02 05 16 01 12 00 46 09 06 00 02 60 03 0A FF 0F 03 11 02 02 02 12 00 02 01 01 02 05 16 01 12 00 46 09 06 00 02 60 03 0A FF 0F 03 11 01 91 D0 7E
Duration: 125
14:39:50 Read object type DisconnectControl index: 2
7E A0 19 21 25 76 AC 0D E6 E6 00 C0 01 C1 00 46 00 01 60 03 0A FF 02 00 FB FA 7E
14:39:50
7E A0 12 25 21 96 B6 2E E6 E7 00 C4 01 C1 00 03 00 3A EB 7E
Duration: 63
14:39:50 Read object type DisconnectControl index: 3
7E A0 19 21 25 98 DC 03 E6 E6 00 C0 01 C1 00 46 00 01 60 03 0A FF 03 00 23 E3 7E
14:39:50
7E A0 12 25 21 B8 CA E6 E6 E7 00 C4 01 C1 00 16 02 01 23 7E
Duration: 63
14:39:50 Read object type DisconnectControl index: 4
7E A0 19 21 25 BA CC 01 E6 E6 00 C0 01 C1 00 46 00 01 60 03 0A FF 04 00 2B AE 7E
14:39:50
7E A0 12 25 21 DA DE A6 E6 E7 00 C4 01 C1 00 16 06 25 65 7E
Duration: 62
7E A0 19 21 25 DC FC 07 E6 E6 00 C0 01 C1 00 46 00 02 60 03 0A FF 02 00 95 52 7E
14:39:50
7E A0 12 25 21 FC EA E2 E6 E7 00 C4 01 C1 00 03 00 3A EB 7E
Duration: 78
7E A0 19 21 25 FE EC 05 E6 E6 00 C0 01 C1 00 46 00 02 60 03 0A FF 03 00 4D 4B 7E
14:39:50
7E A0 12 25 21 1E F6 26 E6 E7 00 C4 01 C1 00 16 02 01 23 7E
Duration: 63
7E A0 19 21 25 10 9C 0B E6 E6 00 C0 01 C1 00 46 00 02 60 03 0A FF 04 00 45 06 7E
14:39:51
7E A0 12 25 21 30 8A EE E6 E7 00 C4 01 C1 00 16 06 25 65 7E
Duration: 78
14:39:51 Read object type DisconnectControl index: 2
7E A0 19 21 25 32 8C 09 E6 E6 00 C0 01 C1 00 46 00 00 60 03 0A FF 02 00 2E 65 7E
14:39:51
7E A0 12 25 21 52 9E AE E6 E7 00 C4 01 C1 00 03 00 3A EB 7E
Duration: 78
14:39:51 Read object type DisconnectControl index: 3
7E A0 19 21 25 54 BC 0F E6 E6 00 C0 01 C1 00 46 00 00 60 03 0A FF 03 00 F6 7C 7E
14:39:51
7E A0 12 25 21 74 AA EA E6 E7 00 C4 01 C1 00 16 02 01 23 7E
Duration: 62
14:39:51 Read object type DisconnectControl index: 4
7E A0 19 21 25 76 AC 0D E6 E6 00 C0 01 C1 00 46 00 00 60 03 0A FF 04 00 FE 31 7E
14:39:51
7E A0 12 25 21 96 B6 2E E6 E7 00 C4 01 C1 00 16 05 BE 57 7E
Duration: 63
14:39:51 Read object type Account index: 2
7E A0 19 21 25 98 DC 03 E6 E6 00 C0 01 C1 00 6F 00 00 13 00 00 FF 02 00 3E A8 7E
14:39:51
7E A0 11 25 21 B8 07 C3 E6 E7 00 C4 01 C1 01 02 FA 93 7E
Duration: 61
Gurux.DLMS.GXDLMSException: Access Error : Device reports a temporary failure.
at GXDLMSDirector.MainForm.ReadDevice(GXDLMSMeter d)
at GXDLMSDirector.MainForm.Read(Object sender, GXAsyncWork work, Object[] parameters)
14:40:17 Disconnect request
7E A0 07 21 25 53 E0 16 7E
14:40:17
7E A0 07 25 21 73 E3 33 7E
Duration: 21
Let me know your thoughts on what the issue could be here. But from what Kamstrup had told us, the issue was addressed and it should be working. Just as a reminder it is connecting to the meter with low level security that has been difficult.
9 months 1 week ago
Hi, I believe that the…
I believe that the Payment mode is not implemented to Account object.
You need to ask this from Kamstrup.
  • Thu, 05/15/2025 - 16:26
    gurux.dlms.c 9.0.2505.1501
  • Wed, 05/14/2025 - 08:30
    gurux.dlms.c 9.0.2505.1401
  • Tue, 05/13/2025 - 10:00
    Gurux.DLMS.Android 2.0.15
  • Fri, 05/09/2025 - 13:03
    Gurux.DLMS.Python 1.0.181
  • Wed, 05/07/2025 - 16:09
    Gurux.DLMS.Android 2.0.14
  • Long reading ends with "Invalid frame ..." error.
  • Push listener example how it works + tcp stream issue
  • Problem with reading energymeter Star DTS27 via GXDLMSDirector
  • Receiver Ready Test Failed
  • Combining several meters' profile generic data into one
