  2. Push Listener For Multiple Meters
By kevin jose minj, 20 May, 2024
In python push listener example which is working properly with one meter if it sends the crictical events. I tested through multiple meters at same time it is not able to dicipher the data , some of meters will fail. Is there any way to modify this example to listen multiple meters?
1 year 10 months ago
Hi, You need to modify the…
You need to modify the reply so there are multiple reply buffers. Each meter must have its own buffer where received data is saved.
So you need to replace this:
self.reply.set(e.data)
something like this:
self.reply = GetReplyBySenderIpAddress()
  • Tue, 04/14/2026 - 11:47
    gurux.dlms.java 4.0.93
  • Mon, 04/13/2026 - 16:12
    gurux.dlms.java 4.0.92
  • Mon, 04/13/2026 - 11:39
    Gurux.DLMS.Net 9.0.2604.1301
  • Tue, 04/07/2026 - 17:17
    Gurux.DLMS.Python 1.0.197
  • Tue, 04/07/2026 - 15:03
    gurux.dlms.c 9.0.2604.0701
