  2. Conformance Test
conformance test
By shagufta, 14 May, 2024
While running confirmation test
/*****Test Report****/
Receiver Ready failed.
Test #1 failed.
Index was out of range. Must be non-negative and less than the size of the collection. Parameter name: index
/***Test Log***/
Starting to execute test for PC.
Starting HDLC tests #1.
Receiver Ready failed.Failed.
<a href="https://www.gurux.fi/gurux.dlms.ctt.tests#hdlc1">Test #1 failed.</a>Starting HDLC tests #2.
Parameter name: indexSystem.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
at Gurux.DLMS.Objects.GXDLMSObjectCollection.get_Item(Int32 index)
at GXDLMSDirector.GXHDLCConformanceTests.T_HDLC_FRAME_P2(GXConformanceTest test, GXConformanceSettings settings, GXDLMSDevice dev, GXOutput output, Int32 tryCount)
at GXDLMSDirector.GXHDLCConformanceTests.HdlcTests(GXConformanceTest test, GXConformanceSettings settings, GXDLMSDevice dev, GXOutput output, Int32 tryCount)
at GXDLMSDirector.GXConformanceTests.ReadXmlMeter(Object data)
11 months 3 weeks ago
Hi, Your meter is sending an…
Your meter is sending an invalid reply. Because there are no hex trace I can't say what is wrong with your message.
  • Tue, 05/20/2025 - 08:40
    gurux.dlms.c 9.0.2505.2001
  • Mon, 05/19/2025 - 10:19
    gurux.net.java 1.0.30
  • Mon, 05/19/2025 - 10:00
    gurux.dlms.c 9.0.2505.1901
  • Thu, 05/15/2025 - 16:26
    gurux.dlms.c 9.0.2505.1501
  • Wed, 05/14/2025 - 08:30
    gurux.dlms.c 9.0.2505.1401
  • HDLC Adress resolver configuration
  • Reading all "Data" object type parameter together
  • com_read getting failed for billing profile and instantaneous profile
  • Simulator connection closed
  • Regarding the dlms android project
