By or, 20 March, 2024 Forums Gurux.DLMS.AMI Hi, every time I do a redeployment that includes the Agent, Server and dlms api services. I need new tokens even if I have a valid token from last time. What can I do to use the same valid token even if I redeployed for these services. Hi, Do you clear the⦠Hi, Do you clear the database? If you do, the token is lost. Agent token is saved to the settings.json file. If you get a new agent you need to copy settings.json file from the old location to the new location. BR, Mikko
Hi, Do you clear theā¦
