  2. Firmware Upload Worked From Local System...Not Working On Server
Firmware upload worked from local system...Not working on Server
By midhun1212, 18 March, 2024
Firmware upload worked from local system...Not working on Server .
ERROR io.undertow.request.handleThrowable -
org.springframework.web.util.NestedServletException: Handler dispatch failed; nested exception is java.lang.IllegalAccessError: tried to access class gurux.dlms.GXFCS16 from class
1 year 3 months ago
Hi, Are you implementing the…
Are you implementing the meter or reading the meter?
Is this happening only when you try to update the firmware?
  • Wed, 07/09/2025 - 16:41
    Gurux.Serial.Android 2.0.13
  • Wed, 07/09/2025 - 12:07
    gurux.dlms.c 9.0.2507.0901
  • Sat, 07/05/2025 - 15:04
    Gurux.DLMS.Python 1.0.188
  • Tue, 07/01/2025 - 10:09
    Gurux.DLMS.Python 1.0.187
  • Tue, 07/01/2025 - 09:54
    gurux.dlms.c 9.0.2507.0101
  • Regarding the dlms android project
  • Unable to read attribute =3 (1.0.94.91.0.255) IC=7 for Indian Metering, while I'm able to read attribute 3 for other Profile generic class
  • Register Activation class (class_id = 9) attribute index 3 data is not visible
  • Load profile
  • DLMS Decryption Implementation Status and Clarification Needed
