  2. Clock_format_optionA, B,C
By Giulia2, 11 March, 2024
Hi all,
I have a question.
I am studying how to sync clock on a meter and I stumbled upon this definition:
"The Deviation and the Clock Status may be defined or may be left undefined:"
Case A:deviaition not specified, clock status not specified
CAse B: deviation not specified, clock status with DST set to 80 or 00
CAse C: deviation is set to deviation from local time to UTC, clock status with DST bit 00.
My question are:
1.When we want to sync meter date, meter has to support all 3 methods?
2,. What is the differenze between solution B ad solution C
3. when we read a meter clock meter has to answer in only one way ,but which of 3 is correct?
Thanks in advances for help
1 year 11 months ago
Hi, This depends on the…
This depends on the meter. The meter defines the deviation and/or clock status used. You USUALLY need to write the deviation clock status in the same format that the meter uses when you read them.
I have to say that there are so many meter implementations from deviation and Daylight Saving Time that I can't give one simple answer to your questions.
  • Sun, 02/01/2026 - 19:47
    gurux.dlms.cpp 9.0.2602.0101
  • Tue, 01/20/2026 - 10:38
    gurux.dlms.java 4.0.89
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Mon, 12/15/2025 - 08:11
    Gurux.DLMS.Net 4.0.87
  • Python GXDLMSTranslator
  • Issue with KWH Value Reading Using Gurux DLMS Library.
  • CEWE Prometer 100
