  2. Every Time Simulator Gives Client Address: 16 Without Authentication.
Every time simulator gives Client address: 16 Without authentication.
Profile picture for user satishchauhan671
By satishchauhan671, 19 February, 2024
Dear Sir,
I am trying to create a high authentication (US) template. Template is created successfully but when i am connecting that template connects only without authentication.
I am using shared format below to create a single phase template for high association.
-S COM3 -o hpl_singlePh.xml -d India -t Verbose -i HDLC -c 32 -a High -P 1111111100000000 -C AuthenticationEncryption -A 0000000000000000 -B 0000000000000000 -v 0.0.43.1.2.255 -T HPL72998
For run template
-p 4060 -x hpl_singlePh.xml -N 10 -d India -t Verbose -i HDLC -a High -c 48 -P 1111111100000000 -C AuthenticationEncryption -A 0000000000000000 -B 0000000000000000 -v 0.0.43.1.3.255 -T HPL72998
After run getting
DLMS HDLC Logical Name simulator start in ports 4060-4069.
Server address: 1
Associations:
Conformance:
[GET]
MaxReceivePduSize: 550 MaxSendPduSize: 550
Client address: 0 Without authentication.
Conformance:
MaxReceivePduSize: 1024 MaxSendPduSize: 0
Conformance:
Conformance:
I want connection with high authentication. I am new please help me for fix this.
Satish Chauhan.
satishchauhan671
1 year 3 months ago
Dear Sir, Please help for…
Dear Sir,
Please help for how to run template for high authentication. I have change clientSAP in xml file also. From 0 to 16, 32 and 48. But after change value of clientSAP it gives invalid authentication tag.
Satish Chauhan.
1 year 3 months ago
Hi Satish, There is…
Hi Satish,
There is something wrong with your simulator template. In your command line parameters, you use High-level authentication, but when you start the simulator it uses None (public) authentication. Can you connect with GXDLMSDirector using High level association for this meter?
  • Wed, 06/04/2025 - 13:35
    gurux.dlms.c 9.0.2506.0401
  • Fri, 05/30/2025 - 08:30
    gurux.dlms.c 9.0.2505.3001
  • Tue, 05/27/2025 - 08:10
    Gurux.Serial.Android 2.0.12
  • Mon, 05/26/2025 - 08:39
    gurux.dlms.c 9.0.2505.2601
  • Tue, 05/20/2025 - 08:40
    gurux.dlms.c 9.0.2505.2001
  • Create gateway protocol in c
  • Error while reading event log object
  • GXDLMS Simulator – AssociationLogicalName Not Listed
  • Failed to read meter through raspberry pi 5 and probe
  • Protocol Version in AARQ Packet
