  2. Losing Smartmeter Connection Frequently
Losing Smartmeter connection frequently
By midhun1212, 15 February, 2024
i am using java for smartmeter connection. Meter connection is lost for about 20 minutes...i cant reconnect to meter or i have to restart meter..Is there any way to connect immediatlly If i lost the connection from meter in java
2 years ago
Hi, You didn't say if are…
You didn't say if are you using a serial port or TCP/IP connection. There is an inactivity timeout. This means that the meter will close the connection after this time if the client doesn't communicate with the meter.
https://www.gurux.fi/Gurux.DLMS.Objects.GXDLMSIecHdlcSetup
You can try to decrease this value. If you don't call Disconnect the connection might get up and you have to wait until inactivity time has elapsed.
  • Sun, 02/01/2026 - 19:47
    gurux.dlms.cpp 9.0.2602.0101
  • Tue, 01/20/2026 - 10:38
    gurux.dlms.java 4.0.89
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Mon, 12/15/2025 - 08:11
    Gurux.DLMS.Net 4.0.87
  • Landisgyr meter
  • GxDateTime always return DayOfWeek as FF
  • Python GXDLMSTranslator
