  2. GXDLMSPushListener
GXDLMSPushListener
By alnardn, 14 February, 2024
Hello! I am using GuruxDLMSPushListenerJavaExample to receive push messages from meter if some event happened(for example, open terminal cover). After i received message from meter I want to send away confirm message that meter message has arrived. How can i make it in GuruxDLMSPushListenerJavaExample?
1 year 3 months ago
Hi, You need just to listen…
You need just to listen to push messages. Make sure that your settings, e.g. TCP/IP port are correct and your listener is receiving data from the meter.
If you have problems, add the hex log here and I can check the correct parameters for you.
alnardn
1 year 3 months ago
So I can't send message to…
So I can't send message to meter? There are lines of code that i can use to send message. What does it mean? Picture is attached.
  • Thu, 05/15/2025 - 16:26
    gurux.dlms.c 9.0.2505.1501
  • Wed, 05/14/2025 - 08:30
    gurux.dlms.c 9.0.2505.1401
  • Tue, 05/13/2025 - 10:00
    Gurux.DLMS.Android 2.0.15
  • Fri, 05/09/2025 - 13:03
    Gurux.DLMS.Python 1.0.181
  • Wed, 05/07/2025 - 16:09
    Gurux.DLMS.Android 2.0.14
  • Long reading ends with "Invalid frame ..." error.
  • Push listener example how it works + tcp stream issue
  • Problem with reading energymeter Star DTS27 via GXDLMSDirector
  • Receiver Ready Test Failed
  • Combining several meters' profile generic data into one
