  2. Svr_run Does Not Provide Demand Register Processing
svr_run does not provide demand register processing
Profile picture for user batulzii
By batulzii, 12 February, 2024
i could not found demand register log and serialize/save (file) in the server samples. Need to write svr_demend()?
Please, advice.
1 year 3 months ago
Hi, You can find the demand…
You can find the demand register example from the here:
https://github.com/Gurux/GuruxDLMS.c/blob/fa855d2e82db1a7d27c419d09ed7a…
batulzii
1 year 3 months ago
Hello, Yes, I found this…
Yes, I found this sample useful. But i could not found how demand register updated and stored. Any scripts or svr_run processing on period?
1 year 3 months ago
Hi, The demand register is…
The demand register is not updated automatically because the status attribute is manufacturer-dependent. It's a shame because if this was defined in the DLMS standard, this could be updated automatically. Now you need to implement this by yourself.
  • Tue, 05/20/2025 - 08:40
    gurux.dlms.c 9.0.2505.2001
  • Mon, 05/19/2025 - 10:19
    gurux.net.java 1.0.30
  • Mon, 05/19/2025 - 10:00
    gurux.dlms.c 9.0.2505.1901
  • Thu, 05/15/2025 - 16:26
    gurux.dlms.c 9.0.2505.1501
  • Wed, 05/14/2025 - 08:30
    gurux.dlms.c 9.0.2505.1401
  • HDLC Adress resolver configuration
  • Reading all "Data" object type parameter together
  • com_read getting failed for billing profile and instantaneous profile
  • Simulator connection closed
  • Regarding the dlms android project
