  2. Generic Profile
Generic Profile
By Ansarr24, 11 January, 2024
Known problems
This value from readRowsByRange(pg, start, end):
[<gurux_dlms.GXDateTime.GXDateTime object at 0x000002A276141190>, 40100, 800, 30700, 700, 1000, 0, 0, 23880, 0, 0, 0], [<gurux_dlms.GXDateTime.GXDateTime object at 0x000002A276141670>, 40100, 800, 30700, 700, 1000, 0, 0, 23916, 0, 0, 0]]
How to correct/format this value "<gurux_dlms.GXDateTime.GXDateTime object at 0x000002A276141190>" ?
1 year 10 months ago
Hi, You need to loop all the…
You need to loop all the cells like it's done in the client example. Check this:
https://github.com/Gurux/Gurux.DLMS.Python/blob/c30bc6346c4fcafeafa2ecf…
  • Tue, 12/02/2025 - 10:21
    gurux.dlms.c 9.0.2512.0201
  • Mon, 12/01/2025 - 13:55
    Gurux.DLMS.Python 1.0.193
  • Thu, 11/13/2025 - 15:23
    Gurux.DLMS.Python 1.0.192
  • Thu, 11/13/2025 - 14:55
    gurux.dlms.java 4.0.84
  • Wed, 10/29/2025 - 08:51
    gurux.dlms.c 9.0.2510.2901
  • SNRM byte mening
  • Itron SL7000 load profile return error
