  3. How to get or install Gurux GXDLMSDirector
By arobles, 20 November, 2023
I need to install the GuruxGXDLMSDirector client, the installer was previously published in the official repository, but it seems that it is no longer available,
thanks,
regards.
1 week 1 day ago
Hi, GXDLMSDirector has…
GXDLMSDirector has always been available only on the downloads page.
https://www.gurux.fi/Download
Tue, 11/21/2023 - 09:55
Gurux.DLMS.AMI4 4.0.2311.2101
Tue, 11/21/2023 - 09:41
Gurux.DLMS.Net 9.0.2311.2101
Thu, 11/16/2023 - 08:52
gurux.dlms.c 20231116.1
Mon, 11/13/2023 - 15:41
Gurux.DLMS.AMI4 4.0.2311.1301
Mon, 11/13/2023 - 13:26
gurux.dlms.c 20231113.1
Open bugs
gurux.dlms.c
4
gurux.dlms.cpp
3
gurux.dlms.delphi
1
  • [Gurux DLMS for C] Error in "loadSettings" function located in "svr_InitObjects" function
  • Power Meter Integration Using DLMS Protocol
  • [Gurux DLMS for C] Problem writing to an attribute of type 'array'
  • Image transfer failing in cosem_checstructure function
  • Index was out of range. Must be non-negative and less than the size of the collection parameter name:index
