  3. List complete policy security configuration basic (configuration security))
By sidney.souza, 21 September, 2023
How would I get the complete list of fields (security policy and suite security) and what attributes should I read?
2 months ago
Hi, Security settings should…
Security settings should be defined on the meter documentation. You need to know what security policy and suite your meter uses or you can't establish the connection for the meter. You need to ask for this information from the meter vendor.
Tue, 11/21/2023 - 09:55
Gurux.DLMS.AMI4 4.0.2311.2101
Tue, 11/21/2023 - 09:41
Gurux.DLMS.Net 9.0.2311.2101
Thu, 11/16/2023 - 08:52
gurux.dlms.c 20231116.1
Mon, 11/13/2023 - 15:41
Gurux.DLMS.AMI4 4.0.2311.1301
Mon, 11/13/2023 - 13:26
gurux.dlms.c 20231113.1
Open bugs
gurux.dlms.c
4
gurux.dlms.cpp
3
gurux.dlms.delphi
1
  • [Gurux DLMS for C] Error in "loadSettings" function located in "svr_InitObjects" function
  • Power Meter Integration Using DLMS Protocol
  • [Gurux DLMS for C] Problem writing to an attribute of type 'array'
  • Image transfer failing in cosem_checstructure function
  • Index was out of range. Must be non-negative and less than the size of the collection parameter name:index
