  • Gurux Club
  3. Current reading not showing in DLMS ER300P meter.
By shabin shanavas, 16 September, 2023
We only connected a load of 40W to the ER300P DLMS meter. Meter showing the values of L1 voltage, Frequency, Active power etc. Is there anything to do from the meter side to show the current reading?
Thank you
6 days 6 hours ago
Hi, I believe you need to…
I believe you need to change the authentication level and client ID. Shown objects might vary depending on the authentication level. Check the used authentication level and client address from the meter documentation.
Fri, 09/22/2023 - 19:50
gurux.dlms.c 20230922.1
Mon, 09/18/2023 - 13:51
Gurux.DLMS.AMI4 4.0.2309.1801
Fri, 09/15/2023 - 12:00
gurux.dlms.c 20230915.1
Tue, 09/12/2023 - 11:10
Gurux.DLMS.AMI4 4.0.2309.1201
Fri, 09/08/2023 - 10:59
gurux.dlms.c 20230908.1
Open bugs
gurux.dlms.c
3
gurux.dlms.cpp
3
gurux.dlms.delphi
1
  • problem with date and time in ION
  • Permament rejected
  • DLMS- GMAC: SNRM, AARQ, AARE is responding but not able to decrypt the Authentication key received from the meter
  • List complete policy security configuration basic (configuration security))
  • Save Association view in database
