  • Gurux Club
  3. ESP32 communication DLMS meter(L&T)
By javid123, 15 September, 2023
hi
i am unable to communicate with meter using esp3.
i even changed this function .
Client.init(true, 32, 1, DLMS_AUTHENTICATION_LOW, YOUR_PASSWORD, DLMS_INTERFACE_TYPE_HDLC);
the error i am getting is
com_initializeConnection failed
in the code exactly at this logic
//Initialize connection.
Serial.println("INSIDE DLMS_ERROR_CODE_OK");
GXTRACE_INT(GET_STR_FROM_EEPROM("com_initializeConnection failed"), ret);
return ret;
any one please let me know where i am doing wrong.
1 week 2 days ago
Hi, Your settings look…
Your settings look correct. Check that your UART is connected correctly. Check baud rate, etc. serial port settings. Check also your wirerings. That is the most common reason for this.
Try to first connect with GXDLMSDirector. I believe tit will help you to get started.
Fri, 09/22/2023 - 19:50
gurux.dlms.c 20230922.1
Mon, 09/18/2023 - 13:51
Gurux.DLMS.AMI4 4.0.2309.1801
Fri, 09/15/2023 - 12:00
gurux.dlms.c 20230915.1
Tue, 09/12/2023 - 11:10
Gurux.DLMS.AMI4 4.0.2309.1201
Fri, 09/08/2023 - 10:59
gurux.dlms.c 20230908.1
Open bugs
gurux.dlms.c
3
gurux.dlms.cpp
3
gurux.dlms.delphi
1
  • problem with date and time in ION
  • Permament rejected
  • DLMS- GMAC: SNRM, AARQ, AARE is responding but not able to decrypt the Authentication key received from the meter
  • List complete policy security configuration basic (configuration security))
  • Save Association view in database
