  2. Gurux.DLMS.AMI.Agent-Issue
By Sourabh, 9 September, 2023
Gurux.DLMS.AMI
Gurux.DLMS.AMI.Agent is configured in AMI and showing connected but it is not able to connect to actual smart meter ..where i can connect to smart meter directly using GXDLMDirector
fail: Gurux.DLMS.AMI.Agent.Worker.GXAgentWorker[0]
2023-09-09 12:53:03 PM Failed to establish the connection. A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
My settings.json file -
{"Id":"b7117686-ea0f-4f00-bc33-6b6df9dcac86","Address":"https://localhost:8001","Token":"86D232BF4A75A46733D8849062C2417D170D88…}
I am trying to connect using TCP ip address and port with interface type WRAPPER
Please help ?
Sourabh
2 years 7 months ago
after doing some config …
after doing some config ..now i am geeting below error ..
info: Gurux.DLMS.AMI.Agent.Worker.GXAgentWorker[0]
00 01 00 30 00 01 00 5F 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 71 77 65 72 74 79 75 69 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 2A 6F 4E 10 42 6C 3E 11 41 14 18 60 35 3F 45 50 BE 23 04 21 21 1F 30 00 00 00 01 34 69 6E 7E 1F 93 97 5A 7D 5E C2 57 45 D1 E5 D7 11 6A 6D DA EF C6 B5 1C 91 EA
00 01 00 01 00 30 00 21 61 1F A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 01 BE 06 04 04 0E 01 06 00
2023-09-09 1:54:08 PM Failed to establish the connection. ServiceError Initiate Error exception. Initiate Other
Hi, Your connection is…
Your connection is ciphered. Check that your block cipher and authentication keys are correct. You can find them from the key management:
https://localhost:44338/config/KeyManagement
  • Tue, 04/14/2026 - 11:47
    gurux.dlms.java 4.0.93
  • Mon, 04/13/2026 - 16:12
    gurux.dlms.java 4.0.92
  • Mon, 04/13/2026 - 11:39
    Gurux.DLMS.Net 9.0.2604.1301
  • Tue, 04/07/2026 - 17:17
    Gurux.DLMS.Python 1.0.197
  • Tue, 04/07/2026 - 15:03
    gurux.dlms.c 9.0.2604.0701
  • FRMR information field translation
  • Connect to EDMI metter
  • Meter rejects reading multiple objects, but it conformance says it supports it.
  • ISKRA ME372 CONNECTION BY DLMSDIRECTOR
