  • Gurux Club
  3. I want to create the meter reading application for the Android mobile
By vaibhav, 29 May, 2023
Gurux DLMS for Android
Please support/ help me to create the application with your Gurux DLMS Andriod application.
Please provide me with the steps to create the mobile application with your GitHub code.
Thanking you
3 months 4 weeks ago
Hi, You can use that example…
You can use that example as a base, but making step by step guide is not possible because DLMS meters are different.
I propose that you download GXDLMSDirector first and play with that. It will help you understand DLMS meters.
Fri, 09/22/2023 - 19:50
gurux.dlms.c 20230922.1
Mon, 09/18/2023 - 13:51
Gurux.DLMS.AMI4 4.0.2309.1801
Fri, 09/15/2023 - 12:00
gurux.dlms.c 20230915.1
Tue, 09/12/2023 - 11:10
Gurux.DLMS.AMI4 4.0.2309.1201
Fri, 09/08/2023 - 10:59
gurux.dlms.c 20230908.1
Open bugs
gurux.dlms.c
3
gurux.dlms.cpp
3
gurux.dlms.delphi
1
  • problem with date and time in ION
  • Permament rejected
  • DLMS- GMAC: SNRM, AARQ, AARE is responding but not able to decrypt the Authentication key received from the meter
  • List complete policy security configuration basic (configuration security))
  • Save Association view in database
