  • Gurux Club
  3. How do I define params for server.example?
By zshajarkar, 28 May, 2023
I'm new to using Gurux and I'm trying to understand how to properly use the parameters . Specifically, I'm wondering what values I need to add for the parameters and how to ensure that the values I'm using are valid.
For example, how would I interpret the value of -t INFO or -S Com1 or -R ln? I'm not sure what each one represents and how to properly use them.
Thanks in advance
3 months 4 weeks ago
Hi, DLMS is quite a…
DLMS is quite a complicated protocol. If one of the parameters is wrong, the meter doesn't reply. I propose that you download GXDLMSDirector and play it with that to get a better understanding from the DLMS.
-t is trace level. It defines that traces are shown.
-s is a serial port. It defines the used serial port.
-r defines is the logical or short name used.
Fri, 09/22/2023 - 19:50
gurux.dlms.c 20230922.1
Mon, 09/18/2023 - 13:51
Gurux.DLMS.AMI4 4.0.2309.1801
Fri, 09/15/2023 - 12:00
gurux.dlms.c 20230915.1
Tue, 09/12/2023 - 11:10
Gurux.DLMS.AMI4 4.0.2309.1201
Fri, 09/08/2023 - 10:59
gurux.dlms.c 20230908.1
Open bugs
gurux.dlms.c
3
gurux.dlms.cpp
3
gurux.dlms.delphi
1
  • problem with date and time in ION
  • Permament rejected
  • DLMS- GMAC: SNRM, AARQ, AARE is responding but not able to decrypt the Authentication key received from the meter
  • List complete policy security configuration basic (configuration security))
  • Save Association view in database
