  • Gurux Club
  3. Unable to use GXArray
Profile picture for user mohit.monga@avonmeters.com
By mohit.monga@av…, 20 April, 2023
Gurux.Net
I want to use Gxarray object, but if I am updating Gurux dll files then i have to update dotnet framwork as well from 4.0.
Please suggest an alternate.
5 months 1 week ago
Hi, I propose that you…
I propose that you update dotnet framework. NET Framework 4.0 hasn't been supported since Jan 12, 2016.
If you want to keep it, you can get the source codes from GitHub and compile it for 4.0.
mohit.monga@av…
5 months ago
Thanks.. It worked..
Fri, 09/22/2023 - 19:50
gurux.dlms.c 20230922.1
Mon, 09/18/2023 - 13:51
Gurux.DLMS.AMI4 4.0.2309.1801
Fri, 09/15/2023 - 12:00
gurux.dlms.c 20230915.1
Tue, 09/12/2023 - 11:10
Gurux.DLMS.AMI4 4.0.2309.1201
Fri, 09/08/2023 - 10:59
gurux.dlms.c 20230908.1
Open bugs
gurux.dlms.c
3
gurux.dlms.cpp
3
gurux.dlms.delphi
1
  • problem with date and time in ION
  • Permament rejected
  • DLMS- GMAC: SNRM, AARQ, AARE is responding but not able to decrypt the Authentication key received from the meter
  • List complete policy security configuration basic (configuration security))
  • Save Association view in database
