  • Gurux Club
  3. Gateway Error
Gateway Error
By dlmsDeveloper, 16 April, 2023
Gurux.Net
Dear Gurux Manager
I use gurux C# library for Read my devices with a gateway
when software is server and gateway is client, between connection and meter reading gateway send DataNotification with 0x66 adress and i get Exception "Destination addresses do not match" , how can i handle this?
This happens both at the beginning of reading and in the middle of reading.
5 months 1 week ago
Hi, Your meter is using the…
Your meter is using the different destination address that you are.
Can you add the hex tracehere so I can check what is happening?
Fri, 09/22/2023 - 19:50
gurux.dlms.c 20230922.1
Mon, 09/18/2023 - 13:51
Gurux.DLMS.AMI4 4.0.2309.1801
Fri, 09/15/2023 - 12:00
gurux.dlms.c 20230915.1
Tue, 09/12/2023 - 11:10
Gurux.DLMS.AMI4 4.0.2309.1201
Fri, 09/08/2023 - 10:59
gurux.dlms.c 20230908.1
Open bugs
gurux.dlms.c
3
gurux.dlms.cpp
3
gurux.dlms.delphi
1
  • problem with date and time in ION
  • Permament rejected
  • DLMS- GMAC: SNRM, AARQ, AARE is responding but not able to decrypt the Authentication key received from the meter
  • List complete policy security configuration basic (configuration security))
  • Save Association view in database
