I send you the log from the gurux serial library that I had today.
I tried to read the Profile Generic billing of the last month with writing access.
The phone and the meted are sending the packages and getting the info but at some point, the meter did not answer and then the library resend the last request packet, after that i only receive trash packets and after a while I receive a ViolatedAccess packet.
I read this meter before, it's a Sagemcom CX1000-6 ES and i should be able to read the info because with another app i've read it successfully.
I put some comments between the logs messages but take a look that at some point the meter don't anwseer the requested packge and the problem occurs when the libary tries to resend the same request packet.
Can you tell me if there's something wrong with the library or where's the problem? I integrated your android serial library into my app and it has been working until I tried this meter that I can read with another app.
I separated the messages by groups so you can understand better
Group 1 is connection with Writing perms
Group 2 is meter id request
Group 3 are the profilegeneric request and all the messages that I received correctly
Croup 4 is where the problem started
Group 5 disconnect
If you take a look the last send packet in group 3 and the first at group 4 is the same with a 5 seconds difference, which is the waiting timeout).
And the last two packets sent on the group 4 are the same again, after the violated acces packet.
GROUP 1
# Access request with Writing permission
[2023-03-79 12:19:19.280] [AsyncTask #1] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0080221039386C17E
[2023-03-79 12:19:19.405] [AsyncTask #1] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA01F030221737342818012050180060180070400000001080400000001533B7E
[2023-03-79 12:19:19.464] [AsyncTask #1] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0450221031043CAE6E6006036A1090607608574050801018A0207808B0760857405080201AC0A80083239343531313236BE10040E01000000065F1F0400001E1DFFFF89C87E
[2023-03-79 12:19:19.792] [AsyncTask #1] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA03803022130A162E6E7006129A109060760857405080101A203020100A305A103020100BE10040E0800065F1F0400001E1D006E00075AC17E
GROUP 2
# Request Meter ID
[2023-03-79 12:19:20.325] [AsyncTask #3] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA01A02210332CDD7E6E600C001C100010000600104FF020065D27E
[2023-03-79 12:19:20.504] [AsyncTask #3] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA02003022152D5CCE6E700C401C100090D53414730313535333439383832D8B87E
GROUP 3
# Request Monthly billing from 1st Feb to 1st March
[2023-03-79 12:19:21.441] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA04D022103982398E6E600C001C100070000620101FF0201010204020412000809060000010000FF0F02120000090C07E7020103000000FFFFC400090C07E7030103000000FFFFC40001005FCA7E
[2023-03-79 12:19:21.954] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA079030221B887A0E6E700C402C10000000001006201020264090C07E70117010E0B30FF800000090C07E7020103000000FF80000006028D9A33060075559F0600A7F6670601704E2D0600000000060000000006000000000600000000060000000006000000000600000000060000000006000000000688D17E
[2023-03-79 12:19:21.965] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103BA35BEE6E600C002C10000000151BE7E
[2023-03-79 12:19:22.248] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA079030221DA93E0E6E700C402C1000000000200620000000006003C2A96060010EF10060010208706001B1AFF0600000000060000000006000000000600000000060000000006000000000600000000060000000006000000000600000000060000000006000000000600000000060000000006000000001C7E
[2023-03-79 12:19:22.258] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103DC05B8E6E600C002C100000002CA8C7E
[2023-03-79 12:19:22.536] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA079030221FCA7A4E6E700C402C1000000000300620006000000000600000000060003B111060001935B06000110930600010D2306000000000600000000060000000006000C52D506000316310600033ABF06000601E506000000000600000000060000000006000000000600000000060000000006007DE97E
[2023-03-79 12:19:22.546] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103FE15BAE6E600C002C100000003439D7E
[2023-03-79 12:19:22.834] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA0790302211EBB60E6E700C402C1000000000400620000000600000000060000000006000000000600015D4906000054080600005593060000B3AE06000000000600000000060000000006000000000600000000060000000006000000000600000000060000000006000000000600000000060000000092AA7E
[2023-03-79 12:19:22.844] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221031065B4E6E600C002C100000004FCE97E
[2023-03-79 12:19:23.095] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA07903022130C7A8E6E700C402C1000000000500620600000000060000000006000000000600000000060000000006000000000600000000060000000006000000000600000000060000000006000000000600001B0E090C07E7011D07000F00FF80000006000015E5090C07E7011B05131E00FF8000003A2D7E
[2023-03-79 12:19:23.105] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221033275B6E6E600C002C10000000575F87E
[2023-03-79 12:19:23.367] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA07903022152D3E8E6E700C402C10000000006006206000018DC090C07E7011F02091E00FF8000000600001B0E090C07E7011D07000F00FF8000000600000000090CFFFFFFFFFFFFFFFFFF8000090600000000090CFFFFFFFFFFFFFFFFFF8000090600000000090CFFFFFFFFFFFFFFFFFF80000902640983DE7E
[2023-03-79 12:19:23.379] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221035445B0E6E600C002C100000006EECA7E
[2023-03-79 12:19:23.634] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA07903022174E7ACE6E700C402C1000000000700620C07E7020103000000FF800000090C07E7030103000000FF8000000602A0B323060079C6B20600AC8FAF06017A5CC2060000000006000000000600000000060000000006000000000600000000060000000006000000000600000000060000000006F8F37E
[2023-03-79 12:19:23.644] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221037655B2E6E600C002C10000000767DB7E
[2023-03-79 12:19:23.906] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA07903022196FB68E6E700C402C100000000080062003E8A680600117792060010A70706001C6BCF06000000000600000000060000000006000000000600000000060000000006000000000600000000060000000006000000000600000000060000000006000000000600000000060000000006000000E5787E
[2023-03-79 12:19:23.916] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221039825BCE6E600C002C10000000890237E
[2023-03-79 12:19:24.165] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA079030221B887A0E6E700C402C100000000090062000600000000060003C04B060001973706000113F7060001151D06000000000600000000060000000006001318F00600047113060004994806000A0E9506000000000600000000060000000006000000000600000000060000000006000000000600BB957E
[2023-03-79 12:19:24.174] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103BA35BEE6E600C002C10000000919327E
[2023-03-79 12:19:24.408] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA079030221DA93E0E6E700C402C1000000000A0062000000060000000006000000000600025FD20600008882060000868006000150D0060000000006000000000600000000060000000006000000000600000000060000000006000000000600000000060000000006000000000600000000060000000090847E
[2023-03-79 12:19:24.417] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103DC05B8E6E600C002C10000000A82007E
[2023-03-79 12:19:24.672] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA079030221FCA7A4E6E700C402C1000000000B006206000000000600000000060000000006000000000600000F3A06000003DC060000036406000007FA0600000000060000000006000000000600001807090C07E7020406030000FF8000000600001650090C07E7020D010B0000FF80000006000016D903CE7E
[2023-03-79 12:19:24.688] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103FE15BAE6E600C002C10000000B0B117E
GROUP 4
# beginning of the communication trash packages
[2023-03-79 12:19:29.706] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103FE15BAE6E600C002C10000000B0B117E
[2023-03-79 12:19:29.804] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221017A967E
[2023-03-79 12:19:29.819] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221031065B4E6E600C002C10000000CB4657E
[2023-03-79 12:19:29.916] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA0080302212178B77E
[2023-03-79 12:19:29.932] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221033275B6E6E600C002C10000000D3D747E
[2023-03-79 12:19:30.027] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221417ED47E
[2023-03-79 12:19:30.042] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221035445B0E6E600C002C10000000EA6467E
[2023-03-79 12:19:30.137] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221617CF57E
[2023-03-79 12:19:30.152] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221037655B2E6E600C002C10000000F2F577E
[2023-03-79 12:19:30.248] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA0080302218172127E
[2023-03-79 12:19:30.257] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221039825BCE6E600C002C10000001059BF7E
[2023-03-79 12:19:30.350] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221A170337E
[2023-03-79 12:19:30.365] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103BA35BEE6E600C002C100000011D0AE7E
[2023-03-79 12:19:30.458] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221C176507E
[2023-03-79 12:19:30.473] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103DC05B8E6E600C002C1000000124B9C7E
[2023-03-79 12:19:30.569] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221E174717E
[2023-03-79 12:19:30.585] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103FE15BAE6E600C002C100000013C28D7E
[2023-03-79 12:19:30.687] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221017A967E
[2023-03-79 12:19:30.703] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221031065B4E6E600C002C1000000147DF97E
[2023-03-79 12:19:30.797] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA0080302212178B77E
[2023-03-79 12:19:30.811] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221033275B6E6E600C002C100000015F4E87E
[2023-03-79 12:19:30.906] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221417ED47E
[2023-03-79 12:19:30.923] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221035445B0E6E600C002C1000000166FDA7E
[2023-03-79 12:19:31.018] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221617CF57E
[2023-03-79 12:19:31.032] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221037655B2E6E600C002C100000017E6CB7E
[2023-03-79 12:19:31.125] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA0080302218172127E
[2023-03-79 12:19:31.139] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221039825BCE6E600C002C10000001811337E
[2023-03-79 12:19:31.233] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221A170337E
[2023-03-79 12:19:31.248] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103BA35BEE6E600C002C10000001998227E
[2023-03-79 12:19:31.347] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221C176507E
[2023-03-79 12:19:31.362] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103DC05B8E6E600C002C10000001A03107E
[2023-03-79 12:19:31.457] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221E174717E
[2023-03-79 12:19:31.476] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103FE15BAE6E600C002C10000001B8A017E
[2023-03-79 12:19:31.579] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221017A967E
[2023-03-79 12:19:31.593] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221031065B4E6E600C002C10000001C35757E
[2023-03-79 12:19:31.689] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA0080302212178B77E
[2023-03-79 12:19:31.703] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221033275B6E6E600C002C10000001DBC647E
[2023-03-79 12:19:31.796] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221417ED47E
[2023-03-79 12:19:31.809] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221035445B0E6E600C002C10000001E27567E
[2023-03-79 12:19:31.904] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221617CF57E
[2023-03-79 12:19:31.918] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221037655B2E6E600C002C10000001FAE477E
[2023-03-79 12:19:32.016] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA0080302218172127E
[2023-03-79 12:19:32.032] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221039825BCE6E600C002C100000020DA8E7E
[2023-03-79 12:19:32.126] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221A170337E
[2023-03-79 12:19:32.140] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103BA35BEE6E600C002C100000021539F7E
[2023-03-79 12:19:32.235] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221C176507E
[2023-03-79 12:19:32.249] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103DC05B8E6E600C002C100000022C8AD7E
[2023-03-79 12:19:32.343] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221E174717E
[2023-03-79 12:19:32.360] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103FE15BAE6E600C002C10000002341BC7E
[2023-03-79 12:19:32.455] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221017A967E
[2023-03-79 12:19:32.468] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221031065B4E6E600C002C100000024FEC87E
[2023-03-79 12:19:32.569] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA0080302212178B77E
[2023-03-79 12:19:32.583] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221033275B6E6E600C002C10000002577D97E
[2023-03-79 12:19:32.680] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221417ED47E
[2023-03-79 12:19:32.696] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221035445B0E6E600C002C100000026ECEB7E
[2023-03-79 12:19:32.789] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221617CF57E
[2023-03-79 12:19:32.802] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221037655B2E6E600C002C10000002765FA7E
[2023-03-79 12:19:32.897] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA0080302218172127E
[2023-03-79 12:19:32.911] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221039825BCE6E600C002C10000002892027E
[2023-03-79 12:19:33.005] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221A170337E
[2023-03-79 12:19:33.019] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103BA35BEE6E600C002C1000000291B137E
[2023-03-79 12:19:33.112] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221C176507E
[2023-03-79 12:19:33.119] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103DC05B8E6E600C002C10000002A80217E
[2023-03-79 12:19:33.211] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221E174717E
[2023-03-79 12:19:33.224] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103FE15BAE6E600C002C10000002B09307E
[2023-03-79 12:19:33.318] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221017A967E
[2023-03-79 12:19:33.329] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221031065B4E6E600C002C10000002CB6447E
[2023-03-79 12:19:33.423] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA0080302212178B77E
[2023-03-79 12:19:33.436] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221033275B6E6E600C002C10000002D3F557E
[2023-03-79 12:19:33.530] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221417ED47E
[2023-03-79 12:19:33.546] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221035445B0E6E600C002C10000002EA4677E
[2023-03-79 12:19:33.639] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221617CF57E
[2023-03-79 12:19:33.652] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221037655B2E6E600C002C10000002F2D767E
[2023-03-79 12:19:33.747] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA0080302218172127E
[2023-03-79 12:19:33.759] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221039825BCE6E600C002C1000000305B9E7E
[2023-03-79 12:19:33.852] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221A170337E
[2023-03-79 12:19:33.863] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103BA35BEE6E600C002C100000031D28F7E
[2023-03-79 12:19:33.956] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221C176507E
[2023-03-79 12:19:33.969] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103DC05B8E6E600C002C10000003249BD7E
[2023-03-79 12:19:34.061] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221E174717E
[2023-03-79 12:19:34.075] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103FE15BAE6E600C002C100000033C0AC7E
[2023-03-79 12:19:34.168] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221017A967E
[2023-03-79 12:19:34.182] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221031065B4E6E600C002C1000000347FD87E
[2023-03-79 12:19:34.278] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA0080302212178B77E
[2023-03-79 12:19:34.285] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221033275B6E6E600C002C100000035F6C97E
[2023-03-79 12:19:34.376] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221417ED47E
[2023-03-79 12:19:34.389] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221035445B0E6E600C002C1000000366DFB7E
[2023-03-79 12:19:34.483] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221617CF57E
[2023-03-79 12:19:34.495] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221037655B2E6E600C002C100000037E4EA7E
[2023-03-79 12:19:34.600] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA0080302218172127E
[2023-03-79 12:19:34.615] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221039825BCE6E600C002C10000003813127E
[2023-03-79 12:19:34.709] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221A170337E
[2023-03-79 12:19:34.722] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103BA35BEE6E600C002C1000000399A037E
[2023-03-79 12:19:34.817] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221C176507E
[2023-03-79 12:19:34.832] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103DC05B8E6E600C002C10000003A01317E
[2023-03-79 12:19:34.927] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221E174717E
[2023-03-79 12:19:34.940] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103FE15BAE6E600C002C10000003B88207E
[2023-03-79 12:19:35.034] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221017A967E
[2023-03-79 12:19:35.047] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221031065B4E6E600C002C10000003C37547E
[2023-03-79 12:19:35.142] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA0080302212178B77E
[2023-03-79 12:19:35.154] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221033275B6E6E600C002C10000003DBE457E
[2023-03-79 12:19:35.249] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221417ED47E
[2023-03-79 12:19:35.265] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221035445B0E6E600C002C10000003E25777E
[2023-03-79 12:19:35.358] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221617CF57E
[2023-03-79 12:19:35.371] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221037655B2E6E600C002C10000003FAC667E
[2023-03-79 12:19:35.464] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA0080302218172127E
[2023-03-79 12:19:35.477] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221039825BCE6E600C002C100000040DCED7E
[2023-03-79 12:19:35.580] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221A170337E
[2023-03-79 12:19:35.592] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103BA35BEE6E600C002C10000004155FC7E
[2023-03-79 12:19:35.687] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221C176507E
[2023-03-79 12:19:35.698] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103DC05B8E6E600C002C100000042CECE7E
[2023-03-79 12:19:35.792] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221E174717E
[2023-03-79 12:19:35.804] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103FE15BAE6E600C002C10000004347DF7E
[2023-03-79 12:19:35.897] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221017A967E
[2023-03-79 12:19:35.909] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221031065B4E6E600C002C100000044F8AB7E
[2023-03-79 12:19:36.003] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA0080302212178B77E
[2023-03-79 12:19:36.016] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221033275B6E6E600C002C10000004571BA7E
[2023-03-79 12:19:36.110] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221417ED47E
[2023-03-79 12:19:36.123] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221035445B0E6E600C002C100000046EA887E
[2023-03-79 12:19:36.217] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221617CF57E
[2023-03-79 12:19:36.230] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221037655B2E6E600C002C10000004763997E
[2023-03-79 12:19:36.325] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA0080302218172127E
[2023-03-79 12:19:36.337] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221039825BCE6E600C002C10000004894617E
[2023-03-79 12:19:36.430] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221A170337E
[2023-03-79 12:19:36.441] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103BA35BEE6E600C002C1000000491D707E
[2023-03-79 12:19:36.536] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221C176507E
[2023-03-79 12:19:36.547] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103DC05B8E6E600C002C10000004A86427E
[2023-03-79 12:19:36.658] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221E174717E
[2023-03-79 12:19:36.670] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103FE15BAE6E600C002C10000004B0F537E
[2023-03-79 12:19:36.763] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221017A967E
[2023-03-79 12:19:36.776] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221031065B4E6E600C002C10000004CB0277E
[2023-03-79 12:19:36.869] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA0080302212178B77E
[2023-03-79 12:19:36.880] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221033275B6E6E600C002C10000004D39367E
[2023-03-79 12:19:36.975] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221417ED47E
[2023-03-79 12:19:36.987] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221035445B0E6E600C002C10000004EA2047E
[2023-03-79 12:19:37.081] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221617CF57E
[2023-03-79 12:19:37.092] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221037655B2E6E600C002C10000004F2B157E
[2023-03-79 12:19:37.185] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA0080302218172127E
[2023-03-79 12:19:37.196] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221039825BCE6E600C002C1000000505DFD7E
[2023-03-79 12:19:37.290] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221A170337E
[2023-03-79 12:19:37.302] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103BA35BEE6E600C002C100000051D4EC7E
[2023-03-79 12:19:37.397] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221C176507E
[2023-03-79 12:19:37.408] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103DC05B8E6E600C002C1000000524FDE7E
[2023-03-79 12:19:37.501] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221E174717E
[2023-03-79 12:19:37.512] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103FE15BAE6E600C002C100000053C6CF7E
[2023-03-79 12:19:37.609] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221017A967E
[2023-03-79 12:19:37.621] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221031065B4E6E600C002C10000005479BB7E
[2023-03-79 12:19:37.714] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA0080302212178B77E
[2023-03-79 12:19:37.726] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221033275B6E6E600C002C100000055F0AA7E
[2023-03-79 12:19:37.818] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221417ED47E
[2023-03-79 12:19:37.829] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221035445B0E6E600C002C1000000566B987E
[2023-03-79 12:19:37.921] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221617CF57E
[2023-03-79 12:19:37.932] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221037655B2E6E600C002C100000057E2897E
[2023-03-79 12:19:38.026] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA0080302218172127E
[2023-03-79 12:19:38.037] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221039825BCE6E600C002C10000005815717E
[2023-03-79 12:19:38.129] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221A170337E
[2023-03-79 12:19:38.140] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103BA35BEE6E600C002C1000000599C607E
[2023-03-79 12:19:38.232] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221C176507E
[2023-03-79 12:19:38.246] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103DC05B8E6E600C002C10000005A07527E
[2023-03-79 12:19:38.341] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221E174717E
[2023-03-79 12:19:38.356] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103FE15BAE6E600C002C10000005B8E437E
[2023-03-79 12:19:38.447] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221017A967E
[2023-03-79 12:19:38.458] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221031065B4E6E600C002C10000005C31377E
[2023-03-79 12:19:38.558] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA0080302212178B77E
[2023-03-79 12:19:38.571] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221033275B6E6E600C002C10000005DB8267E
[2023-03-79 12:19:38.668] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221417ED47E
[2023-03-79 12:19:38.679] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221035445B0E6E600C002C10000005E23147E
[2023-03-79 12:19:38.771] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221617CF57E
[2023-03-79 12:19:38.788] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221037655B2E6E600C002C10000005FAA057E
[2023-03-79 12:19:38.880] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA0080302218172127E
[2023-03-79 12:19:38.885] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221039825BCE6E600C002C100000060DECC7E
[2023-03-79 12:19:38.975] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221A170337E
[2023-03-79 12:19:38.986] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103BA35BEE6E600C002C10000006157DD7E
[2023-03-79 12:19:39.078] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221C176507E
[2023-03-79 12:19:39.089] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103DC05B8E6E600C002C100000062CCEF7E
[2023-03-79 12:19:39.181] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221E174717E
[2023-03-79 12:19:39.192] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA014022103FE15BAE6E600C002C10000006345FE7E
[2023-03-79 12:19:39.285] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221017A967E
[2023-03-79 12:19:39.297] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221031065B4E6E600C002C100000064FA8A7E
[2023-03-79 12:19:39.389] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA0080302212178B77E
[2023-03-79 12:19:39.400] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221033275B6E6E600C002C100000065739B7E
[2023-03-79 12:19:39.492] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221417ED47E
[2023-03-79 12:19:39.503] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221035445B0E6E600C002C100000066E8A97E
[2023-03-79 12:19:39.598] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA008030221617CF57E
[2023-03-79 12:19:39.609] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221037655B2E6E600C002C10000006761B87E
[2023-03-79 12:19:39.702] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA0080302218172127E
[2023-03-79 12:19:39.713] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221039825BCE6E600C002C10000006896407E
[2023-03-79 12:19:44.900] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA0140221039825BCE6E600C002C10000006896407E
[2023-03-79 12:19:55.045] [AsyncTask #4] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> RX: 7EA07103022196DB32E6E700C402C1010000000C00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000007EA017030221B88C60E6E700C402C10100000068010D98087E
GROUP 5
# Disconnection
[2023-03-79 12:19:55.060] [AsyncTask #5] DEBUG net.gisce.giscedistri.MainActivity [Logger.kt:19] -> TX: 7EA012022103BAAD85E6E6006203800100BD9B7E
Hi, I have checked the…
I have checked the problem.
The client is asking the next block and the meter starts to ask next frame from the client. This will continue until meter sends AccessViolated error.
In short: This is a meter issue. You need to ask if there is a firmware update available that fixes this for the meter.
Hi, I just remembered this…
I just remembered this. Sagemcom is using its own solution here.
The meter can't read the data from memory fast enough and the meter sends the ACK and hopes that you wait some time and ask for the next part of the data after this delay.
This is really nasty because it will work without problems when you have fewer rows in the buffer. It will start to work like this after there are enough rows in the profile generic buffer.
Ask the meter vendor if there is a firmware update available for the meter. This is causing problems because no one else is working like this.
Hi, so do you think if I put…
Hi, so do you think if I put a little delay (like 100 or 150 milliseconds) between packages, it should work?
I'll try it.
Thanks.
Marc Ruiz
Hi, Yes, it will work, but…
Yes, it will work, but the delay must be bigger, try with 500 ms. If I remember correctly, the length of the delay depends on the number of lines. The more rows, the longer the delay.
Try something like this:
public void ReadDataBlock(byte[] data, GXReplyData reply)
ReadDLMSPacket(data, reply);
bool addDelay = false;
lock (Media.Synchronous)
while (reply.IsMoreData && Client.ConnectionState != ConnectionState.None)
if (reply.IsStreaming())
data = null;
else
data = Client.ReceiverReady(reply);
if ((reply.MoreData & RequestTypes.DataBlock) != 0)
addDelay = true;
if (addDelay)
Thread.Sleep(500);
