When using a certificate. When signing one-pass is selected, meter authentication succeeds, but the software does not send data and reports errors during meter reading. Can you help me see what the problem is?
There should be no problem with the key, as my authentication was successful and it was possible to read the meter successfully when signing selected the other two items. Please see the attachment for the error when selecting one-pass. I want to say that the error occurred when reading the meter after the meter certification was successful.
The configuration is as…
The configuration is as follows
Hi, 1. Can you explain what…
1. Can you explain what this error says?
2. Check that your client keys are same as in the meter. You can verify this by reading Security Setup object.
https://www.gurux.fi/Gurux.DLMS.Objects.GXDLMSSecuritySetup
3. Check that your client server key is the same as in the meter.
Usually the problem is that the keys are different in the client and in the meter.
Hi, There should be no…
Hi,I have encountered the…
Hi,I have encountered the same problem. Have you solved this problem?
