-g argument in client not working with AttributeIndex Object type
Project:
gurux.dlms.cpp
Hi.
After I "make" the client CPP. with a successful bin file. I am executing it using the terminal with all arguments.
I am trying -g argument for Attribute index value 2(Containing Objects{...} ) for "BlockLoad profile" in "ProfileGeneric", So when I use
-g (blockLoadProfile_IP):2
Same with other profiles i.,e..,(DailyLoadProfile,InstantaneousProfile,....) containing object type in Attribute index.
I am getting an error at the end of execution i.e..,:
"Error! Index: 2 read failed: Invalid parameter."
in LogFile.txt.
"trace.txt" has RX and TX values, no errors shown in that file.
The same is working well for other index values with -g and also when I use without -g I am able to see the blockLoad profile "entries" and all its values including for objectTypes.
Have been stuck on this for sometime need support..!
Thanks in advance...
Status:
Active
Priority:
Normal
Category:
Support request
Component:
Code
Reporter:
ashray.a14@gmail.com
Created:
Fri, 11/18/2022 - 15:56
Updated:
Fri, 11/18/2022 - 16:06
Comments
Body: Old » New
Title: -g argument in client not working with BlockLoadProfile » -g argument in client not working with AttributeIndex Object type
Body: Old » New
