By vibhorkhurana, 29 September, 2022 Forums General discussion I have received the below data from the meter 00 01 00 01 00 05 00 AF C2 01 0C 07 E6 09 1B 02 10 0F 00 FF 80 00 00 00 28 00 09 16 09 00 FF 02 19 09 0C 07 E6 09 1B 02 10 0F 00 FF 80 00 00 04 28 E6 00 03 00 00 15 00 00 00 00 00 00 00 00 15 00 00 00 00 00 00 00 00 15 00 00 00 00 00 00 00 00 15 00 00 00 00 00 00 00 00 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 05 00 00 27 10 05 00 00 27 10 12 13 8B 06 00 00 00 00 06 00 05 1E D9 05 00 00 27 10 06 00 00 00 00 06 00 00 00 00 05 00 00 27 10 06 00 00 00 00 06 00 00 00 00 05 00 00 27 10 06 00 05 1E D9 06 00 00 00 00 06 00 05 1E D9 However, using Push listener in python not able to decode the complete output, only getting the below output <WRAPPER len="B7" > <TargetAddress Value="1" /> <SourceAddress Value="5" /> <PDU> <EventNotificationRequest> <!--09/27/22 16:15:00--> <Time Value="07E6091B02100F00FF800000" /> <AttributeDescriptor> <!--ObjectType.PUSH_SETUP--> <ClassId Value="0028" /> <!--0.9.22.9.0.255--> <InstanceId Value="0009160900FF" /> <AttributeId Value="02" /> </AttributeDescriptor> <AttributeValue> <!--07/16:47:16--> <DateTime Value="" /> </AttributeValue> </EventNotificationRequest> </PDU> </WRAPPER> Can someone please help. Hi, Hi, Your meter is sending only one date-time value. If you want to send multiple values they must be in the structure like this: C2 01 0C 07 E6 09 1B 02 10 0F 00 FF 80 00 00 00 28 00 09 16 09 00 FF 02 02 19 // Add this. 19 09 0C 07 E6 09 1B 02 10 0F 00 FF 80 00 00 04 28 E6 00 03 00 00 15 00 00 00 00 00 00 00 00 15 00 00 00 00 00 00 00 00 15 00 00 00 00 00 00 00 00 15 00 00 00 00 00 00 00 00 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 05 00 00 27 10 05 00 00 27 10 12 13 8B 06 00 00 00 00 06 00 05 1E D9 05 00 00 27 10 06 00 00 00 00 06 00 00 00 00 05 00 00 27 10 06 00 00 00 00 06 00 00 00 00 05 00 00 27 10 06 00 05 1E D9 06 00 00 00 00 06 00 05 1E D9 If you haven't implement this meter, you need to ask meter manufacturer to fix it. BR, Mikko Log in or register to post comments
02 19 // Add this.
