Those certificates are in PEM format (txt). You don't need to change anything.
Note! There must be own certificate for each meter. There is a server system title on each certificate and it must match for the server system title.
Check this. It will download the certificate and save it for the file and it's used later.
https://github.com/Gurux/gurux.dlms.java/blob/250a86fda9ec481aabf485fca…
Check also this:
https://www.gurux.fi/PublicKeyCryptography
