Please, don't add images. They are hard to read. Plain text is better.
Some meters expect that milliseconds or week day are not used and some expected that those are set.
Try to read the clock from the meter and then write it back.
Check with GXDLMSDirector that you have access right to the time attribute. You can see it by selecting the clock object and then selecting "Access rights" tab. There should be "Read, Write" on the Access column.
I tried with High Level Security. It seems successful but when I read again it shows me 01.01.0001. my code below: (please also have a look at manufacturer documentation at the very below)
Manufacturer documentation is using the ciphered connection, so it doesn't help. Your meter is returning an invalid reply when you write the clock. As I told you before, read the time from the meter and then write it back.
It might be that you need to write clock object using ciphering. I can't say anything from the manufacturer's example because I don't know the authentication and clock cipher keys.
Some meter manufacturers are using UTC data object for the time. Check if there is a UTC clock in data objects and if you can write the new data for that.
var date = DateTime.Now;
clock.Time = new GXDateTime(date.Year,date.Month,date.Day,date.Hour,date.Minute,0,0);
result.AppendLine(_reader.ReadDataBlock(_settings.Client.Write(clock, 2), reply).ToString());
TX: 09:41:02 00 01 00 01 00 01 00 2E C9 2C 30 00 00 00 0B 2A 1B 39 56 0A 20 D7 B4 07 7F 48 43 DF 68 41 96 B8 46 D7 61 B4 87 8F 06 75 F3 76 D4 66 F1 4E BA EB B4 80 2B F2 06 4C
RX: 09:41:04 00 01 00 01 00 01 00 17 CD 15 30 00 00 00 0B C3 91 2E 6F D0 7A 17 F9 EC 02 12 B2 62 FE 35 59
Gurux.DLMS.GXDLMSException: Access Error : Device reports Read-Write denied.
at DLMSClient.GXDLMSReader.ReadDLMSPacket(Byte[] data, GXReplyData reply) in C:\Repos\DLMSClient\GXDLMSReader.cs:line 1398
at DLMSClient.GXDLMSReader.ReadDataBlock(Byte[] data, GXReplyData reply) in C:\Repos\DLMSClient\GXDLMSReader.cs:line 1432
at DLMSClient.GXDLMSReader.ReadDataBlock(Byte[][] data, GXReplyData reply) in C:\Repos\DLMSClient\GXDLMSReader.cs:line 1418
at DLMSClient.Program.Main(String[] args) in C:\Repos\DLMSClient\Program.cs:line 376
I will keep in mind to add plain text.
_reader.AddToClientObject($"0.0.1.0.0.255", ObjectType.Clock);
_reader.GetScalersAndUnits();
result.AppendLine(_reader.GetReadOut());
Console.WriteLine("Date: " + result);
var reply = new GXReplyData();
GXDateTime newTime = new GXDateTime(DateTime.Now);
var clock = new GXDLMSClock($"0.0.1.0.0.255")
Time = newTime
result.AppendLine(_reader.ReadDataBlock(_settings.Client.Write(clock, 3), reply).ToString());
result.AppendLine(_reader.ReadDataBlock(_settings.Client.Write(clock, 5), reply).ToString());
result.AppendLine(_reader.ReadDataBlock(_settings.Client.Write(clock, 6), reply).ToString());
result.AppendLine(_reader.ReadDataBlock(_settings.Client.Write(clock, 7), reply).ToString());
result.AppendLine(_reader.ReadDataBlock(_settings.Client.Write(clock, 8), reply).ToString());
Console.WriteLine(result);
My code output:
Send SNRM request.7E A0 07 03 03 93 8C 11 7E
Info: Receive-Send Waiting Time: 30 sn.
TX: 14:03:26 7E A0 07 03 03 93 8C 11 7E
RX: 14:03:27 7E A0 20 03 03 73 F0 2E 81 80 14 05 02 02 00 06 02 00 00 07 04 00 00 00 01 08 04 00 00 00 01 BB 12 7E
Parsing UA reply.81 80 14 05 02 02 00 06 02 00 00 07 04 00 00 00 01 08 04 00 00 00 01
Parsing UA reply succeeded.
Send AARQ request 7E A0 4C 03 03 10 BD 71 E6 E6 00 60 3E A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 66 41 5F 6B 1C 44 2D 23 49 29 3C 5B 47 54 1C 4F BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF 79 AD 7E
TX: 14:03:27 7E A0 4C 03 03 10 BD 71 E6 E6 00 60 3E A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 66 41 5F 6B 1C 44 2D 23 49 29 3C 5B 47 54 1C 4F BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF 79 AD 7E
RX: 14:03:29 7E A0 58 03 03 30 F2 E1 E6 E7 00 61 4A A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 12 80 10 77 30 39 76 8B AF 92 02 71 6F F7 3B 63 96 E8 61 BE 10 04 0E 08 00 06 5F 1F 04 00 00 18 18 01 C2 00 07 E9 39 7E
Parsing AARE reply61 4A A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 12 80 10 77 30 39 76 8B AF 92 02 71 6F F7 3B 63 96 E8 61 BE 10 04 0E 08 00 06 5F 1F 04 00 00 18 18 01 C2 00 07
Parsing AARE reply succeeded.
Date: 1.0.0(01-01-01,00:00)(0)(Ok)(01-01-01,00:00)(01-01-01,00:00)(0)(False)
TX: 14:05:12 7E A0 27 03 03 32 5C 2A E6 E6 00 C1 01 C1 00 08 00 00 01 00 00 FF 02 00 09 0C 07 E6 09 01 FF 0E 05 0C FF FF 4C 00 95 F2 7E
RX: 14:05:13 7E A0 07 03 03 87 29 47 7E
TX: 14:05:13 7E A0 1C 03 03 54 8B A0 E6 E6 00 C1 01 C1 00 08 00 00 01 00 00 FF 03 00 10 00 00 A1 AB 7E
TX: 14:05:13 7E A0 1B 03 03 76 BA F5 E6 E6 00 C1 01 C1 00 08 00 00 01 00 00 FF 05 00 09 00 DA 1D 7E
RX: 14:05:14 7E A0 07 03 03 87 29 47 7E
TX: 14:05:14 7E A0 1B 03 03 98 CA FB E6 E6 00 C1 01 C1 00 08 00 00 01 00 00 FF 06 00 09 00 17 38 7E
RX: 14:05:15 7E A0 07 03 03 87 29 47 7E
TX: 14:05:15 7E A0 1B 03 03 BA DA F9 E6 E6 00 C1 01 C1 00 08 00 00 01 00 00 FF 07 00 0F 00 7C 70 7E
RX: 14:05:16 7E A0 07 03 03 87 29 47 7E
TX: 14:05:16 7E A0 1B 03 03 DC EA FF E6 E6 00 C1 01 C1 00 08 00 00 01 00 00 FF 08 00 03 00 25 6B 7E
RX: 14:05:17 7E A0 07 03 03 87 29 47 7E
Writing (clock, 2)
True
Writing (clock, 3)
True
Writing (clock, 5)
True
Writing (clock, 6)
True
Writing (clock, 7)
True
Writing (clock, 8)
True
Disconnecting from the meter.
TX: 14:05:17 7E A0 11 03 03 FE 54 21 E6 E6 00 62 03 80 01 00 BD 9B 7E
RX: 14:05:18 7E A0 07 03 03 87 29 47 7E
TX: 14:05:18 7E A0 07 03 03 53 80 D7 7E
RX: 14:05:19 7E A0 07 03 03 1F E8 5F 7E
Manufacturer documentation shows below:
Send: 2F 3F 21 0D 0A
Receive: 2F 54 43 45 35 5C 32 54 43 45 31 32 0D 0A
Send: 06 32 35 32 0D 0A
Receive: 06 32 35 32 0D 0A
Send: 7E A0 07 03 03 93 8C 11 7E
Receive: 7E A0 20 03 03 73 F0 2E 81 80 14 05 02 01 F5 06 02 01 F5 07 04 00 00 00 01 08 04 00 00 00 01 6F 19 7E
Send: 7E A0 6F 03 03 10 23 DB E6 E6 00 60 61 80 02 07 80 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 00 00 00 00 00 00 00 00 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 C8 5E 09 75 0E 47 96 19 F5 F1 C5 A0 62 7A 45 58 BE 23 04 21 21 1F 30 00 00 00 00 02 88 DA CE 66 E9 BC 96 F3 28 BC A6 75 02 5C 0B C3 48 4E 60 3F 6E 56 4C DA 3F 89 A9 7E
Receive: 7E A0 77 03 03 30 58 DC E6 E7 00 61 69 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 45 44 4D 00 30 7D BF 68 88 02 07 80 89 07 60 85 74 05 08 02 05 AA 12 80 10 23 1E AF 6A 4F 99 53 F3 33 15 0C 03 A3 95 5A 52 BE 23 04 21 28 1F 30 00 00 00 00 07 AC 38 78 E3 FE D2 E1 D1 43 A5 D5 58 37 0F B1 C6 0D 93 41 53 36 8A 67 AB CB E1 36 7E
Send: 7E A0 3F 03 03 32 25 0C E6 E6 00 CB 31 30 00 00 00 02 12 16 A1 9B 7C 5D F6 84 68 3C 13 CA 96 0A 00 E9 71 9D 7C 72 0D DA 8A 7C D7 70 33 BA 6A 36 82 1D 66 2D 3F 04 79 61 DD 46 9D 6F F3 83 4E 61 7E
Receive: 7E A0 38 03 03 52 02 38 E6 E7 00 CF 2A 30 00 00 00 02 42 47 25 F8 18 07 21 2F C6 FA 6D 71 00 44 65 50 92 EC 40 84 86 DC 2A E9 67 9A F7 68 02 92 07 16 AA E3 E5 78 55 E8 65 7E
Write(SET) RTC {8,0-0:1.0.0.255,2} Start
Send: 7E A0 3A 03 03 54 42 64 E6 E6 00 C9 2C 30 00 00 00 03 42 89 B2 64 60 EF 77 B1 05 96 93 E8 8F B3 B4 F3 0E D7 73 A8 4E 76 F5 9D 48 A1 B2 F4 0E 0B 9F BE EC 42 B4 1A A9 E7 87 72 43 7E
Receive: 7E A0 23 03 03 74 82 7F E6 E7 00 CD 15 30 00 00 00 03 4E B1 5B 38 33 22 24 9E 9C 10 6C B4 8C 56 9A F7 91 06 7E
Write(SET) RTC {8,0-0:1.0.0.255,2} Success!
Write(SET) RTC {8,0-0:1.0.0.255,3} Start
Send: 7E A0 2F 03 03 76 A4 CB E6 E6 00 C9 21 30 00 00 00 04 DA 40 DC 70 FC 2C 1A 71 7B 59 E8 4F 55 65 FA 7B 00 D2 A6 DA 7F 7F 11 ED 4D 7A 40 70 18 F3 7E
Receive: 7E A0 23 03 03 96 9E BB E6 E7 00 CD 15 30 00 00 00 04 45 55 0D 26 02 B7 46 3F BC 0C EE 67 22 D7 4C 36 C4 DF 7E
Write(SET) RTC {8,0-0:1.0.0.255,3} Success!
Write(SET) RTC {8,0-0:1.0.0.255,5} Start
Send: 7E A0 3A 03 03 98 22 68 E6 E6 00 C9 2C 30 00 00 00 05 16 9C 32 A1 42 51 8E EA F3 4F DC E8 9D 67 DC 7D E7 72 5F 07 37 F9 7C DB BF 1F 5C A9 50 BD 2A 96 38 88 EB 2B 74 67 26 28 3C 7E
Receive: 7E A0 23 03 03 B8 E2 73 E6 E7 00 CD 15 30 00 00 00 05 68 A8 42 86 9C 4E AF 97 DB FD DD E4 D9 AE 85 80 67 1F 7E
Write(SET) RTC {8,0-0:1.0.0.255,5} Success!
Write(SET) RTC {8,0-0:1.0.0.255,6} Start
Send: 7E A0 3A 03 03 BA 32 6A E6 E6 00 C9 2C 30 00 00 00 06 03 50 39 9E 9B 70 40 F8 3C 4D 5E A0 E4 E2 E2 85 FD E2 73 30 2F 09 AE A7 2D A0 B7 1E 86 D7 A9 01 45 70 0C 74 60 42 4A A8 23 7E
Receive: 7E A0 23 03 03 DA F6 33 E6 E7 00 CD 15 30 00 00 00 06 64 2D 75 6D FE FB C1 37 E2 E7 77 E9 F9 84 61 E9 34 44 7E
Write(SET) RTC {8,0-0:1.0.0.255,6} Success!
Write(SET) RTC {8,0-0:1.0.0.255,7} Start
Send: 7E A0 2E 03 03 DC 4F DD E6 E6 00 C9 20 30 00 00 00 07 E8 5F C5 F2 3A C2 2D 30 1A 78 B7 25 62 A3 C1 57 28 E3 90 3B 13 B7 43 28 A1 2E 1E 89 34 7E
Receive: 7E A0 23 03 03 FC C2 77 E6 E7 00 CD 15 30 00 00 00 07 FE A7 B6 19 28 84 14 12 AF C0 EB 32 43 51 27 E7 AE 63 7E
Write(SET) RTC {8,0-0:1.0.0.255,7} Success!
Write(SET) RTC {8,0-0:1.0.0.255,8} Start
Send: 7E A0 2E 03 03 FE 5F DF E6 E6 00 C9 20 30 00 00 00 08 4A 21 B8 DB 77 D6 97 DB DE A2 E7 50 DF F8 AA 8A 19 0A BA C0 B9 15 B0 F7 19 8C 4B AB B1 7E
Receive: 7E A0 23 03 03 1E DE B3 E6 E7 00 CD 15 30 00 00 00 08 91 1F D7 13 ED 84 08 4C AE 63 AB 9D D2 E4 F5 A7 A9 02 7E
Write(SET) RTC {8,0-0:1.0.0.255,8} Success!
Send: 7E A0 07 03 03 53 80 D7 7E
Do you think I should use ciphering as manufacturer does? How can I so?
I tried reading clock and writing back the same value. Please find below log trace.
TX: 14:42:24 7E A0 07 03 03 93 8C 11 7E
! Received byte count:34
Final! Received byte count:34
RX: 14:42:25 7E A0 20 03 03 73 F0 2E 81 80 14 05 02 02 00 06 02 00 00
00 01
08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 76 18 58 57 5B 52 6
7 56 21 5A 77 27 51 03 3C 0F BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF
FF D4 71 7E
TX: 14:42:25 7E A0 4C 03 03 10 BD 71 E6 E6 00 60 3E A1 09 06 07 60 85
74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 76 18 58 57 5
B 52 67 56 21 5A 77 27 51 03 3C 0F BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E
5D FF FF D4 71 7E
! Received byte count:124
Final! Received byte count:124
RX: 14:42:26 7E A0 58 03 03 30 F2 E1 E6 E7 00 61 4A A1 09 06 07 60 85
5 08 02 02 AA 12 80 10 B7 87 12 B2 6C A9 1F D1 A5 81 04 06 B6 BA 59 34 BE 10 04
0E 08 00 06 5F 1F 04 00 00 18 18 01 C2 00 07 40 D5 7E
03 02 01 00 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 12 80 10 B7 87 12 B2 6C A
9 1F D1 A5 81 04 06 B6 BA 59 34 BE 10 04 0E 08 00 06 5F 1F 04 00 00 18 18 01 C2
00 07
Read scalers and units from the device.
-------- Reading GXDLMSClock 0.0.1.0.0.255
TX: 14:42:33 7E A0 19 03 03 32 EC C8 E6 E6 00 C0 01 C1 00 08 00 00 01
00 00 FF 02 00 60 1A 7E
! Received byte count:133
Final! Received byte count:133
RX: 14:42:34 7E A0 07 03 03 87 29 47 7E
Index: 2 Value: 1.1.0001 02:00:00
TX: 14:42:34 7E A0 19 03 03 54 DC CE E6 E6 00 C0 01 C1 00 08 00 00 01
00 00 FF 03 00 B8 03 7E
! Received byte count:142
Final! Received byte count:142
RX: 14:42:35 7E A0 07 03 03 87 29 47 7E
Index: 3 Value: 0
TX: 14:42:35 7E A0 19 03 03 76 CC CC E6 E6 00 C0 01 C1 00 08 00 00 01
00 00 FF 04 00 B0 4E 7E
! Received byte count:151
Final! Received byte count:151
Index: 4 Value: Ok
TX: 14:42:35 7E A0 19 03 03 98 BC C2 E6 E6 00 C0 01 C1 00 08 00 00 01
00 00 FF 05 00 68 57 7E
! Received byte count:160
Final! Received byte count:160
RX: 14:42:36 7E A0 07 03 03 87 29 47 7E
Index: 5 Value: 1.1.0001 02:00:00
TX: 14:42:36 7E A0 19 03 03 BA AC C0 E6 E6 00 C0 01 C1 00 08 00 00 01
00 00 FF 06 00 00 7D 7E
! Received byte count:169
Final! Received byte count:169
RX: 14:42:37 7E A0 07 03 03 87 29 47 7E
Index: 6 Value: 1.1.0001 02:00:00
TX: 14:42:37 7E A0 19 03 03 DC 9C C6 E6 E6 00 C0 01 C1 00 08 00 00 01
00 00 FF 07 00 D8 64 7E
! Received byte count:178
Final! Received byte count:178
Index: 7 Value: 0
TX: 14:42:37 7E A0 19 03 03 FE 8C C4 E6 E6 00 C0 01 C1 00 08 00 00 01
00 00 FF 08 00 10 E7 7E
! Received byte count:187
Final! Received byte count:187
RX: 14:42:38 7E A0 07 03 03 87 29 47 7E
Index: 8 Value: False
TX: 14:42:38 7E A0 19 03 03 10 FC CA E6 E6 00 C0 01 C1 00 08 00 00 01
00 00 FF 09 00 C8 FE 7E
TX: 14:43:08 7E A0 19 03 03 10 FC CA E6 E6 00 C0 01 C1 00 08 00 00 01
TX: 14:43:38 7E A0 19 03 03 10 FC CA E6 E6 00 C0 01 C1 00 08 00 00 01
Error! GXDLMSClock 0.0.1.0.0.255Index: 9 Failed to receive reply from the device
in given time.
at DLMSClient.DLMSReader.ReadDLMSPacket(Byte[] data, GXReplyData reply) in C:
\Repos\DLMSClient\DLMSReader.cs:line 199
at DLMSClient.DLMSReader.ReadDataBlock(Byte[] data, GXReplyData reply) in C:\
Repos\DLMSClient\DLMSReader.cs:line 104
at DLMSClient.DLMSReader.ReadDataBlock(Byte[][] data, GXReplyData reply) in C
:\Repos\DLMSClient\DLMSReader.cs:line 149
at DLMSClient.DLMSReader.Read(GXDLMSObject it, Int32 attributeIndex) in C:\Re
pos\DLMSClient\DLMSReader.cs:line 270
at DLMSClient.DLMSReader.GetReadOut() in C:\Repos\DLMSClient\DLMSReader.cs:li
ne 486
TX: 14:44:08 7E A0 27 03 03 32 5C 2A E6 E6 00 C1 01 C1 00 08 00 00 01
00 00 FF 02 00 09 0C 07 E6 09 01 FF 0E 2C 08 FF FF 4C 00 96 7F 7E
! Received byte count:196
Final! Received byte count:196
RX: 14:44:09 7E A0 07 03 03 87 29 47 7E
TX: 14:44:09 7E A0 1C 03 03 54 8B A0 E6 E6 00 C1 01 C1 00 08 00 00 01
! Received byte count:205
Final! Received byte count:205
RX: 14:44:10 7E A0 07 03 03 87 29 47 7E
TX: 14:44:10 7E A0 1B 03 03 76 BA F5 E6 E6 00 C1 01 C1 00 08 00 00 01
! Received byte count:214
Final! Received byte count:214
RX: 14:44:11 7E A0 07 03 03 87 29 47 7E
TX: 14:44:11 7E A0 1B 03 03 98 CA FB E6 E6 00 C1 01 C1 00 08 00 00 01
! Received byte count:223
Final! Received byte count:223
TX: 14:44:11 7E A0 1B 03 03 BA DA F9 E6 E6 00 C1 01 C1 00 08 00 00 01
! Received byte count:232
Final! Received byte count:232
RX: 14:44:12 7E A0 07 03 03 87 29 47 7E
TX: 14:44:12 7E A0 1B 03 03 DC EA FF E6 E6 00 C1 01 C1 00 08 00 00 01
! Received byte count:241
Final! Received byte count:241
RX: 14:44:13 7E A0 07 03 03 87 29 47 7E
True
True
True
True
True
True
TX: 14:44:13 7E A0 11 03 03 FE 54 21 E6 E6 00 62 03 80 01 00 BD 9B 7E
! Received byte count:250
Final! Received byte count:250
TX: 14:44:13 7E A0 07 03 03 53 80 D7 7E
! Received byte count:259
Final! Received byte count:259
RX: 14:44:14 7E A0 07 03 03 1F E8 5F 7E
Hi Aaron,
Hi Aaron,
When I read then write the same object to the meter I don't get any error.
TX: 09:36:16 00 01 00 01 00 10 00 2E C9 2C 30 00 00 00 0B 2A 1B 39 56 0A 20 D7 B4 07 7F 48 43 DF 68 41 96 B8 46 D7 9B B4 8A 9F F9 0A BF 76 AD DF AE F9 92 54 80 BC 80 74 D2 8B
RX: 09:36:18 00 01 00 10 00 01 00 17 CD 15 30 00 00 00 0B C3 91 2E 6C 2B 0D 88 2B EF 77 72 EB D9 5B 03 4F
When I change the time after read the clock object, not succesful.
System title: 00 00 00 00 00 00 00 00
Authentication key: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Block cipher key 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
