By 953313493@qq.com, 23 May, 2022 Forums General discussion python support xml client? is there any python xml client demo ? Hi, Hi, XML client example is not implemented for Python at the moment. BR, Mikko ok ,so ok ,so java and C# is implemented C++ nocode for xml client python is not implemented right ? Hi, Hi, Yes. Those are the programming languages that our clients have asked for. Support for XML client can be added at some point for Python and C++, but I don't have an exact time for that yet. BR, Mikko Hi, Hi, One of our clients asked for support for Python and it's now added. https://github.com/Gurux/Gurux.DLMS.Python/tree/master/Gurux.DLMS.XmlCl… BR, Mikko thankyou thankyou I donot know if it is the bug , both in c# and python when use xml to read block both in get and action in c# I need to fix settings.command when to recv block like that , other wise cmd=none ``` def handleMethodResponse(cls, settings, data, index): type_ = int(data.data.getUInt8()) data.invokeId = data.data.getUInt8() if data.xml: data.xml.appendStartTag(Command.METHOD_RESPONSE) data.xml.appendStartTag(Command.METHOD_RESPONSE, type_) data.xml.appendLine(TranslatorTags.INVOKE_ID, None, data.xml.integerToHex(data.invokeId, 2)) if type_ == ActionResponseType.NORMAL: GXDLMS.handleActionResponseNormal(settings, data) elif type_ == 2: settings.command=0xc3 --------------------------------------add it GXDLMS.handleActionResponseWithBlock(settings, data, index) elif type_ == 3: raise ValueError("Invalid Command.") ``` error pdu like that if I do error pdu like that if I do not fix it TX: 17:18:44 00 01 00 11 00 01 00 19 C3 01 C1 00 7B 00 00 12 00 00 FF 02 01 02 02 11 00 02 02 12 00 01 12 F4 47 RX: 17:18:44 00 01 00 01 00 11 02 57 C7 02 C1 00 00 00 00 01 82 02 4C 01 82 02 55 02 09 0A 01 30 0A 05 39 39 39 39 39 0A 01 31 0A 00 0A 01 31 0A 0A 30 30 30 30 30 30 30 30 30 30 0A 00 0A 00 0A 00 02 09 0A 01 30 0A 06 38 38 38 38 38 38 0A 01 32 0A 00 0A 01 31 0A 0A 30 30 30 30 30 30 30 30 30 30 0A 00 0A 00 0A 00 02 09 0A 01 30 0A 02 31 35 0A 01 32 0A 00 0A 01 31 0A 0A 30 30 30 30 30 30 30 30 30 30 0A 00 0A 00 0A 00 02 09 0A 01 30 0A 02 31 36 0A 01 32 0A 00 0A 01 31 0A 0A 30 30 30 30 30 30 30 30 30 30 0A 00 0A 00 0A 00 02 09 0A 01 30 0A 02 31 37 0A 01 31 0A 00 0A 01 31 0A 0A 30 30 30 30 30 30 30 30 30 30 0A 00 0A 00 0A 00 02 09 0A 01 30 0A 02 31 38 0A 01 31 0A 00 0A 01 31 0A 0A 30 30 30 30 30 30 30 30 30 30 0A 00 0A 00 0A 00 02 09 0A 01 30 0A 02 31 39 0A 01 31 0A 00 0A 01 31 0A 0A 30 30 30 30 30 30 30 30 30 30 0A 00 0A 00 0A 00 02 09 0A 01 30 0A 03 32 31 33 0A 01 31 0A 00 0A 01 31 0A 0A 30 30 30 30 30 30 30 30 30 30 0A 00 0A 00 0A 00 02 09 0A 01 30 0A 03 32 31 34 0A 01 31 0A 00 0A 01 31 0A 0A 30 30 30 30 30 30 30 30 30 30 0A 00 0A 00 0A 00 02 09 0A 01 30 0A 03 32 31 35 0A 01 31 0A 00 0A 01 31 0A 0A 30 30 30 30 30 30 30 30 30 30 0A 00 0A 00 0A 00 02 09 0A 01 30 0A 03 32 31 36 0A 01 31 0A 00 0A 01 31 0A 0A 30 30 30 30 30 30 30 30 30 30 0A 00 0A 00 0A 00 02 09 0A 01 30 0A 03 32 31 37 0A 01 31 0A 00 0A 01 31 0A 0A 30 30 30 30 30 30 30 30 30 30 0A 00 0A 00 0A 00 02 09 0A 01 30 0A 03 32 31 38 0A 01 31 0A 00 0A 01 31 0A 0A 30 30 30 30 30 30 30 30 30 30 0A 00 0A 00 0A 00 02 09 0A 01 30 0A 03 32 31 39 0A 01 31 0A 00 0A 01 31 0A 0A 30 30 30 30 30 30 30 30 30 30 0A 00 0A 00 0A 00 02 09 0A 01 30 0A 03 32 32 30 0A 01 31 0A 00 0A 01 31 0A 0A 30 30 30 30 30 30 30 30 30 30 0A 00 0A 00 0A 00 02 09 0A 01 30 0A 03 32 32 31 0A 01 31 0A 00 0A 01 31 0A 0A 30 30 30 30 30 30 30 30 30 30 0A 00 0A 00 0A 00 02 09 0A 01 30 0A 03 32 TX: 17:18:44 00 01 00 11 00 01 00 04 00 00 00 01 RX: 17:18:44 00 01 00 01 00 11 00 03 D8 02 05 TX: 17:18:44 00 01 00 11 00 01 00 04 00 00 00 02 RX: 17:18:44 00 01 00 01 00 11 00 03 D8 02 05 TX: 17:18:44 00 01 00 11 00 01 00 04 00 00 00 03 RX: 17:18:44 00 01 00 01 00 11 00 03 D8 02 05 TX: 17:18:44 00 01 00 11 00 01 00 04 00 00 00 04 Hi, Hi, Please, create a new topic if you have a new question. Create a new topic and add a hex trace from all the frames so I can check what is causing this. BR, Mikko Log in or register to post comments
ok ,so
ok ,so
right ?
thankyou
thankyou
if data.xml:
elif type_ == 2:
elif type_ == 3:
