You need to connect to the meter using a High authentication level. If the object's access rights is ReadWrite then you can write the value. Try to connect using GXDLMSDirector and try to write the value with that first. I believe it will help you to get an idea of how to write value for the DLMS meter.
yes i understand the writing proces but i want to know if it is possible to write a token for a prepaid meter access via dlms. i mean is it possible to recharge my meter via that writing process
recharging meters via obis
recharging meters via obis /dlms protocol
That depends on the meter. If the meter supports that and you have the access right for the meter it's possible.
