What brand/model Bluetooth optical probe would you recommend to connect via DLMS? (i.e to meter Landis+Gyr E650)
also, I'm planning to create a Bluetooth implementation of the GXMedia2 interface in .NET, any suggestion or recommendations?
Vincent
There are a lot of models from different manufacturers, but don't buy the cheapest. Make sure that the optical probe supports IEC62056-21 mode E. ANSI C12.18 doesn't work.
Bluetooth media is done and going for testing. It will work only in Windows at the moment. It's released at the beginning of February.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Do you have a particular brand in mind, perhaps the one you've used for testing ?
Have a good day.
Vincent
This is used in a few projects:
https://www.german-metering.com/optical-probe-bluetooth-op-730.html
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
