  • Gurux Club
  2. Atmel port fail to send retry transmissions
By JReis, 7 January, 2022
Project
gurux.dlms.c
Status
Active
I'm porting the DLMS.c to esp32 IDF and I used the Atmel port as base reference.
On the main.c, funtion uart_write, the bytes between data->position and data->size are transmitted.
After the first transmission, data->position is equal to data->size. In case of retry transmissions, it will not transmit because of that.
The data->position should not be changed or should be restored to the original value.
Priority
Normal
Category
Bug report
Fri, 09/22/2023 - 19:50
gurux.dlms.c 20230922.1
Mon, 09/18/2023 - 13:51
Gurux.DLMS.AMI4 4.0.2309.1801
Fri, 09/15/2023 - 12:00
gurux.dlms.c 20230915.1
Tue, 09/12/2023 - 11:10
Gurux.DLMS.AMI4 4.0.2309.1201
Fri, 09/08/2023 - 10:59
gurux.dlms.c 20230908.1
Open bugs
gurux.dlms.c
3
gurux.dlms.cpp
3
gurux.dlms.delphi
1
  • problem with date and time in ION
  • Permament rejected
  • DLMS- GMAC: SNRM, AARQ, AARE is responding but not able to decrypt the Authentication key received from the meter
  • List complete policy security configuration basic (configuration security))
  • Save Association view in database
