An error occurred while collecting objects from the server.
Project:
gurux.dlms.c
After receiving all server objects in the first block, the client requests the next block, and the server responds with an empty one (see Log).
Error in gxget.c getLNObjects (). After inserting the current association object into the transmit queue, incremented the counter data block for transmit, but did not increment the counter data block sent for transmit.
Status:
Closed (fixed)
Priority:
Major
Category:
Bug report
Component:
Code
Reporter:
fon Luck
Created:
Wed, 12/01/2021 - 09:05
Updated:
Fri, 05/27/2022 - 08:59
Comments
Kurumi's picture
This is tested and it works without problems. Do you have the latest version? Are you using malloc on the server size?
Work good with DLMSDirector v.8.2.2202.0901 and library 20220209.1.
Administrator's picture
Status: Active » Closed (fixed)
