Error when extracting PDU in block fragmented messages
Project:
gurux.dlms.c
File dlms.c, line 5209, function dlms_getPdu()
As the client receives PDUs they are queued into the data->data buffer. If the response of the meter is of type Set-response-datablock, the client always deletes the position of the last queued PDU by resetting the position to 0 or 1:
if (!settings->server || data->command == DLMS_COMMAND_AARE || data->command == DLMS_COMMAND_AARQ)
data->data.position = 0;
else
data->data.position = 1;
Status:
Active
Priority:
Normal
Category:
Bug report
Component:
Code
Reporter:
gunmox
Created:
Thu, 10/28/2021 - 23:36
Updated:
