System.Exception: Not enough data.
Can you add sent and received bytes as a hex?
please check the below log reply for your reference. this happens when I am trying to connect to the meter.
GXDLMSDirector 8.2.2107.2101
Log created 12:36:01
12:36:04 Initializing Network connection.
12:36:04 Send AARQ request.
00 01 00 30 00 01 00 5F 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 31 32 33 34 35 36 37 38 8A 02 07 80 8B 07 60 85 74 05 08 02 07 AC 12 80 10 50 0F 2D 30 05 44 05 64 30 61 5D 48 25 73 4A 27 BE 23 04 21 21 1F 31 00 00 00 00 A5 C9 10 AF E4 9C DC DA F0 CD AA 4E 8B 29 7C BD 0D DE CA 36 78 8A EB 74 9C CC
12:36:04
00 01 00 01 00 30 00 97 61 81 95 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 01 BE 7B 04 79 28 77 31 00 00 00 02 F7 F2 D6 B5 E7 F7 62 AB EF 07 E1 81 73 DF 11 A3 50 7C 30 81 49 45 B6 63 BB 8D FA 66 DD 55 B2 BB B8 0C 50 DB C4 1B D3 7B 6A 55 34 3A E5 5A 18 83 56 AC 41 66 7D 4B 1A 84 0B 1C F1 21 1F 98 24 8E B2 71 6E 78 B6 5B 4F 0A 16 79 88 86 41 5A 72 46 DD 73 9B FB B8 E7 3D C0 09 CB 16 FE B1 16 91 D5 DC 6A C2 53 1A 87 77 E4 49 AD F4 1A 58 93 13 2A 57 80
thank you
One byte is missing from the reply and it's causing this.
61 81 95 //There are only 148 bytes. This must be fixed for the meter.
Meter doesn't accept the connection and returns the PermanentRejected error. Because I don't have the certificates I can't check this.
please check the below-updated log reply for your reference.
Log created 12:28:23
12:28:26 Initializing Network connection.
12:28:26 Send AARQ request.
00 01 00 30 00 01 00 5F 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 31 32 33 34 35 36 37 38 8A 02 07 80 8B 07 60 85 74 05 08 02 07 AC 12 80 10 61 01 45 5E 08 3C 09 61 0B 12 3E 68 75 6B 37 02 BE 23 04 21 21 1F 31 00 00 00 00 A5 C9 10 AF E4 9C DC DA F0 CD AA 4E 8B 29 7C BD 0D DE CA 36 78 8A EB 74 9C CC
<WRAPPER len="67" >
<TargetAddress Value="30" />
<SourceAddress Value="1" />
<PDU>
<AssociationRequest>
<CallingAPTitle Value="3132333435363738" />
<MechanismName Value="HighECDSA" />
<CallingAuthentication Value="6101455E083C09610B123E68756B3702" />
<glo_InitiateRequest Value="3100000000A5C910AFE49CDCDAF0CDAA4E8B297CBD0DDECA36788AEB749CCC" />
</AssociationRequest>
</PDU>
</WRAPPER>
12:28:26
00 01 00 01 00 30 00 97 61 81 95 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 01 BE 7B 04 79 28 77 31 00 00 00 03 D6 D7 90 F5 75 7F AA 54 1B BB 69 8C 17 39 35 88 BD 21 84 8C 24 01 E6 D2 D5 E9 56 C3 44 71 B4 BE CE E1 DD 95 0A 45 37 99 DF EA 80 33 69 96 F5 62 C4 B9 CB 67 E4 1B 2F CA CC 49 18 65 0B 58 3F 62 84 33 4E 67 AC DF BD 59 7F 09 40 02 7B 34 22 B6 BE D3 8C A7 36 D7 98 FD 03 6D 8B 47 A9 8E FE E5 3A 0D CD FE E9 73 3D 8B 54 4A 57 51 50 F5 F1 A4 20 98
<WRAPPER len="9F" >
<TargetAddress Value="1" />
<SourceAddress Value="30" />
<PDU>
<AssociationResponse>
<AssociationResult Value="01" />
<ResultSourceDiagnostic>
<ACSEServiceUser Value="01" />
</ResultSourceDiagnostic>
<glo_InitiateResponse Value="3100000003D6D790F5757FAA541BBB698C17393588BD21848C2401E6D2D5E956C34471B4BECEE1DD950A453799DFEA80336996F562C4B9CB67E41B2FCACC4918650B583F6284334E67ACDFBD597F0940027B3422B6BED38CA736D798FD036D8B47A98EFEE53A0DCDFEE9733D8B544A575150F5F1A42098" />
</AssociationResponse>
</PDU>
</WRAPPER>
thank you
