i am new to fetch the meter reading data from dlms lnt meter using the optical port so now i am facing the
problem
this is my view log GXDLMS Director:
17:50:48 Initializing serial connection.
17:50:48 Send SNRM request.
7E A0 07 03 65 93 09 20 7E
17:50:48 Received data
7E A0 1E 65 03 73 D4 1F 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
17:50:48 Parsing UA reply.<CR><LF>81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01
17:50:48 Parsing UA reply succeeded.
17:50:48 Send AARQ request
7E A0 40 03 65 10 0C D7 E6 E6 00 60 32 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 06 80 04 6C 6E 74 31 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 FE 1F FF FF 0B 25 7E
image was setting for lnt GXDLMS settings so pls help me to get the solution
Your settings look correct and you can establish the connection to the meter and there should be no reason why the meter is not replying. Is the password correct? Can you connect with public authentication?
