Read Data For incoming connections
2 posts / 0 new
Last post
ajaywazir
In Gurux AMI, is it going to be possible read object values for meters connected via 4G, using DHCP and incoming connections.
Presently, apparently, I cannot read object values on demand for incoming connections
Ajay
Kurumi's picture
Hi Ajay,
Yes, it's possible. Open appsettings.xml and set correct Listener settings. Meters are behaving differently with this and with some meters server address might be different, so you need to set correct address to ServerAddress.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
