The meter is sending encrypted push messages. Do you have the block cipher and authentication keys so you can decrypt the data?
You don't need to establish the connection to the meter if you want only to receive push data.
Check push listener example how you can handle received data:
I have forgotten, the error
I have forgotten, the error message was : frame not fully received
Best regards
https://github.com/Gurux/Gurux.DLMS.Net/tree/master/Gurux.DLMS.Push.Lis…
You need to set the correct block cipher and authentication keys so you can decrypt the received data.
