Hi there
I'm new to this protocol and i want to add our Meter feature to this package and read the data.How can i do that .Please kindly help me
Thank you
Project | Open issue count |
gurux.dlms.cpp | 1 |
gurux.dlms.delphi | 1 |
gurux.dlms.c | 1 |
GXDLMSDirector | 1 |
gurux.dlms.java | 1 |
Gurux.DLMS.Python | 1 |
gurux.dlms.c | 1 |
Gurux.DLMS.Net | 1 |
gurux.dlms.c | 1 |
gurux.dlms.c | 1 |
gurux.dlms.c | 1 |
gurux.dlms.c | 1 |
gurux.dlms.c | 1 |
gurux.dlms.c | 1 |
gurux.dlms.c | 1 |
gurux.dlms.c | 1 |
If you can read the meter with GXDLMSDirector send the manufacturer settings file to me.
You can find manufacturer setting files from here:
C:\ProgramData\Gurux\OBIS
After it's released you can see your settings in Gurux.DLMS.Android example application and read the meter.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Thanks for reply
There is no manufacturer name for my meter
How can I initial setting for my meter to read the meter?
Best Regards
Read this:
https://www.gurux.fi/GXDLMSDirector.Manufacturers
The easiest way is if you rename grx.obx to your company flag name. Then modify Gurux settings for your needs.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Is there any other solution to add meter's manufacturer settings to DLMS source code by me?
Best Regards
You can hard code the settings to the source code. Find GXDLMSSecureClient constructor and set correct parameters.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
