Add array of structures to Value of GXDLMSData.
4 posts / 0 new
Last post
Yuriy
Good day!
I make my practice in Gurux.DLMS.Server.Example.Net project. I need to add specific array to Value of GXDLMSData. Array ought to be an array of structures. I didn't find example of such code in project.
For example there is adding of symple UInt32 dataType:
void AddInvocationCounter()
GXDLMSData d = new GXDLMSData("0.0.43.1.0.255");
d.Value = 0;
d.SetDataType(2, DataType.UInt32);
//Set initial value for invocation counter.
d.Value = (UInt32)100;
Items.Add(d);
And how can I add array of structures?
struct Example
meter_id //octet-string
addr //unsigned
void AddArrayOfStructures()
GXDLMSData d = new GXDLMSData("0.0.49.1.0.255");
d.Value = 0;
d.SetDataType(2, DataType.Array);
Items.Add(d);
I hope for your help...
Kurumi's picture
You can add it like this:
GXArray arr = new GXArray();
GXStructure struc = new GXStructure();
struc.Add((UInt16) 1);
struc.Add((UInt32) 1);
d.Value = arr;
arr.Add(struc);
Make sure that your data types are correct or the meter is returning an exception.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
Yuriy
Thank you for quick response. I'll try.
Yuriy
Works correct. Thank you!
