By rajacms, 10 March, 2021 Forums General discussion Dear Mikko, Can i use Gurux DLMS Conformance Test Tool, can i do all test like HDLC Tests, APPL Tests,COSEM Tests Etc.. how mach it will support... Please let me know Gurux DLMS Conformance Test Tool Hi, Hi, It will do most of the test, but the current implementation does not compare the settings between _CTI file. The DLMS CTT test will fail if you haven't set the correct parameters for the _CTI file. I believe that this is the problem in your case. BR, Mikko Log in or register to post comments
