Missing newlines in logfile
Project:
Gurux.DLMS.Python
The logfile is written without newlines between the records, proposed patch:
diff --git a/Gurux.DLMS.Client.Example.python/GXDLMSReader.py b/Gurux.DLMS.Client.Example.python/GXDLMSReader.py
index a339d47..30d9562 100644
--- a/Gurux.DLMS.Client.Example.python/GXDLMSReader.py
+++ b/Gurux.DLMS.Client.Example.python/GXDLMSReader.py
@@ -110,7 +110,7 @@ class GXDLMSReader:
def writeTrace(self, line, level):
if self.trace >= level:
print(line)
- self.logFile.write(line)
+ self.logFile.write(line + "\n")
def readDLMSPacket(self, data, reply=None):
if not reply:
Status:
Closed (fixed)
Priority:
Normal
Category:
Bug report
Component:
Code
Reporter:
bsdphk
Created:
Fri, 08/07/2020 - 10:57
Updated:
Fri, 08/07/2020 - 11:54
Comments
Administrator's picture
This is fixed.
Status: Active » Closed (fixed)
Thanks, that was quick :-)
One other thing: You may want to consider calling .flush() after each write, otherwise the logfile doesn't show anything until the program either terminates or has filled th 4k/16k/whatever size write bufer.
