  2. Landisgyr Meter
Landisgyr meter
By Zulu@eyabantup…, 16 February, 2026
hi Am trying to connect the Gurux GXDLMS Director to the landisgyr meter and it has a CU-XE communication module. There are no Obis codes in the software, and it says failed to receive reply from device. can you help? I can only connect with the MAP110 from landisgyr but with Gurux is giving me problems.
  • Thu, 02/19/2026 - 11:51
    gurux.dlms.cpp 9.0.2602.1901
  • Sun, 02/01/2026 - 19:47
    gurux.dlms.cpp 9.0.2602.0101
  • Tue, 01/20/2026 - 10:38
    gurux.dlms.java 4.0.89
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Gurux C library DLMS book edition support
  • Help with connection and read with landis+gyr e650 + CU-E22 using python
  • Preestablished connection
  • RJ11 to RS232 Pin out SECURE Premier 300
  • GENUS sugam 3 PH bidirectional
