I'm trying to build app for get meter serial number using Android DLMS package. not able to get data from the meter.
My code is:
import android.os.Bundle;
import android.os.Handler;
import android.os.Looper;
import android.util.Log;
import android.widget.Button;
import android.widget.TextView;
import android.widget.Toast;
import androidx.appcompat.app.AppCompatActivity;
import java.util.concurrent.ExecutorService;
import java.util.concurrent.Executors;
import gurux.common.ReceiveParameters;
import gurux.common.enums.TraceLevel;
import gurux.common.GXCommon;
import gurux.dlms.GXDLMSClient;
import gurux.dlms.GXReplyData;
import gurux.dlms.enums.Authentication;
import gurux.dlms.enums.InterfaceType;
import gurux.dlms.objects.GXDLMSData;
import gurux.io.BaudRate;
import gurux.io.Parity;
import gurux.io.StopBits;
import gurux.serial.GXPort;
import gurux.serial.GXSerial;
public class MainActivity extends AppCompatActivity {
private static final String TAG = "MeterReader";
private TextView tvMeterValue;
private TextView tvStatus;
private Button btnRead;
private GXSerial media;
private GXDLMSClient client;
private final Handler uiHandler = new Handler(Looper.getMainLooper());
private final ExecutorService executor = Executors.newSingleThreadExecutor();
private final Object serialLock = new Object();
@Override
protected void onCreate(Bundle savedInstanceState) {
super.onCreate(savedInstanceState);
setContentView(R.layout.activity_main);
tvMeterValue = findViewById(R.id.tvMeterValue);
tvStatus = findViewById(R.id.tvStatus);
btnRead = findViewById(R.id.btnRead);
client = new GXDLMSClient(
true,
32,
1,
Authentication.LOW,
"lnt1",
InterfaceType.HDLC
media = new GXSerial(this);
media.setTrace(TraceLevel.VERBOSE);
btnRead.setOnClickListener(v -> startRead());
private void startRead() {
btnRead.setEnabled(false);
tvMeterValue.setText("---");
logStatus("Scanning for ports...");
executor.execute(() -> {
try {
synchronized (serialLock) {
if (!media.isOpen()) {
GXPort[] ports = media.getPorts();
if (ports == null || ports.length == 0) {
throw new Exception("No optical probe detected. Please reconnect it.");
media.setPort(ports[0]);
media.setBaudRate(BaudRate.BAUD_RATE_9600);
media.setDataBits(8);
media.setParity(Parity.NONE);
media.setStopBits(StopBits.ONE);
logStatus("Opening: " + ports[0].getPort());
media.open();
try {
media.setRtsEnable(true);
media.setDtrEnable(true);
} catch (Exception e) {
Log.w(TAG, "Failed to set control lines", e);
Thread.sleep(1000);
logStatus("Connecting to meter...");
initializeConnection();
logStatus("Reading Serial Number...");
GXDLMSData snObj = new GXDLMSData("0.0.96.1.0.255");
// Read attribute 2 (Value)
readDLMS(client.read(snObj, 2), reply);
final String serialNum = String.valueOf(reply.getValue());
uiHandler.post(() -> {
tvMeterValue.setText(serialNum);
btnRead.setEnabled(true);
Toast.makeText(this, "Read Successful!", Toast.LENGTH_SHORT).show();
logStatus("Success");
logStatus("Error: " + e.getMessage());
Log.e(TAG, "Communication error", e);
uiHandler.post(() -> btnRead.setEnabled(true));
try {
media.close();
} catch (Exception ignored) {
private void initializeConnection() throws Exception {
// 1. SNRM
logStatus("Sending SNRM...");
readDLMS(client.snrmRequest(), reply);
// 2. AARQ
logStatus("Sending AARQ...");
readDLMS(client.aarqRequest(), reply);
private void readDLMS(byte[] data, GXReplyData reply) throws Exception {
readDLMS(new byte[][]{data}, reply);
private void readDLMS(byte[][] data, GXReplyData reply) throws Exception {
if (data == null) return;
for (byte[] frame : data) {
if (frame == null || frame.length == 0) continue;
media.resetSynchronousBuffer();
Log.d(TAG, "TX: " + GXCommon.bytesToHex(frame));
media.send(frame);
reply.clear();
long startTime = System.currentTimeMillis();
while (!reply.isComplete()) {
if (System.currentTimeMillis() - startTime > 10000) {
throw new Exception("Meter response timeout");
ReceiveParameters<byte[]> rp = new ReceiveParameters<>(byte[].class);
rp.setWaitTime(5000);
rp.setEop((byte) 0x7E); // HDLC frame end character
rp.setCount(1); // Wait for at least 1 byte
if (media.receive(rp)) {
byte[] response = rp.getReply();
if (response != null && response.length > 0) {
Log.d(TAG, "RX: " + GXCommon.bytesToHex(response));
client.getData(response, reply);
if (reply.getError() != 0) {
throw new Exception("DLMS Error Code: " + reply.getError());
private void logStatus(String msg) {
uiHandler.post(() -> tvStatus.setText(msg));
Log.d(TAG, msg);
@Override
protected void onDestroy() {
super.onDestroy();
executor.shutdownNow();
if (media != null) {
try {
media.close();
Catlog Output: cat log: …
Catlog Output:
cat log:
2026-01-31 11:47:15.755 4298-4298 MirrorManager com.example.meterreader W this model don't Support
2026-01-31 11:47:15.759 4298-4298 MiuiMultiWindowUtils com.example.meterreader D freeform resolution args raw data:{ "wide_default":{ "freeform_args": { "vertical_portrait":{"aspect_ratio":0.626, "original_ratio":0.5643,"original_scale":0.74,"top_margin":0.168,"left_margin":0.484}, "horizontal_portrait":{"aspect_ratio":0.626, "original_ratio":0.5643,"original_scale":0.74,"top_margin":0.1222,"left_margin":0.59745}, "vertical_landscape":{"aspect_ratio":1.6, "original_ratio":1,"original_scale":0.604,"top_margin":0.2596,"left_margin":0.2624}, "horizontal_landscape":{"aspect_ratio":1.6, "original_ratio":1,"original_scale":0.604,"top_margin":0.213,"left_margin":0.3758} }, "mini_freeform_args":{ "vertical_portrait":{"original_ratio":0.147}, "horizontal_portrait":{"original_ratio":0.147}, "vertical_landscape":{"original_ratio":0.165}, "horizontal_landscape":{"original_ratio":0.165} } }, "narrow_default": { "freeform_args": { "vertical_portrait":{"aspect_ratio":0.626, "original_ratio":1,"original_scale":0.74,"top_margin":0.0753,"left_margin":-1}, "horizontal_portrait":{"aspect_ratio":0.626, "original_ratio":1,"original_scale":0.5756,"top_margin":-1,"left_margin":0.0753}, "vertical_landscape":{"aspect_ratio":1.6, "original_ratio":0.6847,"original_scale":0.587,"top_margin":0.0753,"left_margin":-1}, "horizontal_landscape":{"aspect_ratio":1.6, "original_ratio":0.6847,"original_scale":0.587,"top_margin":-1,"left_margin":0.0753} }, "mini_freeform_args":{ "vertical_portrait":{"original_ratio":0.26}, "horizontal_portrait":{"original_ratio":0.26}, "vertical_landscape":{"original_ratio":0.293}, "horizontal_landscape":{"original_ratio":0.293} } }, "regular_default": { "freeform_args": { "vertical_portrait":{"aspect_ratio":0.625, "original_ratio":1,"original_scale":0.7,"top_margin":0.109,"left_margin":-1}, "horizontal_portrait":{"aspect_ratio":0.6667, "original_ratio":1,"original_scale":0.6102,"top_margin":-1,"left_margin":0.026}, "vertical_landscape":{"aspect_ratio":1.6, "original_ratio":1,"original_scale":0.4244,"top_margin":0.109,"left_margin":-1}, "horizontal_landscape":{"aspect_ratio":1.6, "original_ratio":1,"original_scale":0.4244,"top_margin":-1,"left_margin":0.026} }, "mini_freeform_args":{ "vertical_portrait":{"original_ratio":0.25}, "horizontal_portrait":{"original_ratio":0.25}, "vertical_landscape":{"original_ratio":0.25}, "horizontal_landscape":{"original_ratio":0.25} } }, "pad_default": { "freeform_args": { "vertical_portrait":{"aspect_ratio":0.5625, "original_ratio":0.375,"original_scale":0.835,"top_margin":0.049,"left_margin":0.2775}, "horizontal_portrait":{"aspect_ratio":0.5625, "original_ratio":0.375,"original_scale":0.835,"top_margin":-1,"left_margin":0.6525}, "vertical_landscape":{"aspect_ratio":-1, "original_ratio":1,"original_scale":0.468,"top_margin":0.049,"left_margin":-1}, "horizontal_landscape":{"aspect_ratio":-1, "original_ratio":1,"original_scale":0.468,"top_margin":-1,"left_margin":0.4976} }, "mini_freeform_args":{ "vertical_portrait":{"original_ratio":0.144}, "horizontal_portrait":{"original_ratio":0.144}, "vertical_landscape":{"original_ratio":0.2}, "horizontal_landscape":{"original_ratio":0.2} } }}
2026-01-31 11:47:15.763 4298-4298 MiuiMultiWindowUtils com.example.meterreader D initFreeFormResolutionArgs failed, device is breeze
2026-01-31 11:47:15.764 4298-4298 IS_CTS_MODE com.example.meterreader D false
2026-01-31 11:47:15.764 4298-4298 MULTI_WIND...CH_ENABLED com.example.meterreader D false
2026-01-31 11:47:15.771 4298-4309 ple.meterreader com.example.meterreader W userfaultfd: MOVE ioctl seems unsupported: Connection timed out
2026-01-31 11:47:15.799 4298-4298 MeterReader com.example.meterreader D Scanning for ports...
2026-01-31 11:47:15.803 4298-4407 Compatibil...geReporter com.example.meterreader D Compat change id reported: 160794467; UID 10393; state: ENABLED
2026-01-31 11:47:15.848 4298-4407 UsbDeviceConnectionJNI com.example.meterreader D close
2026-01-31 11:47:15.850 4298-4407 MeterReader com.example.meterreader D Opening: /dev/bus/usb/002/003
2026-01-31 11:47:16.866 4298-4407 MeterReader com.example.meterreader D Connecting to meter...
2026-01-31 11:47:16.871 4298-4407 MeterReader com.example.meterreader D Sending SNRM...
2026-01-31 11:47:16.890 4298-4407 MeterReader com.example.meterreader D TX: 7E A0 07 03 41 93 5A 64 7E
2026-01-31 11:47:26.896 4298-4407 MeterReader com.example.meterreader D Error: Meter response timeout
2026-01-31 11:47:26.899 4298-4407 MeterReader com.example.meterreader E Communication error (Explain with AI) java.lang.Exception: Meter response timeout
at com.example.meterreader.MainActivity.readDLMS(MainActivity.java:178)
at com.example.meterreader.MainActivity.readDLMS(MainActivity.java:156)
at com.example.meterreader.MainActivity.initializeConnection(MainActivity.java:148)
at com.example.meterreader.MainActivity.lambda$startRead$3$com-example-meterreader-MainActivity(MainActivity.java:112)
at com.example.meterreader.MainActivity$$ExternalSyntheticLambda4.run(D8$$SyntheticClass:0)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1154)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:652)
at java.lang.Thread.run(Thread.java:1563)
2026-01-31 11:47:26.899 4298-4407 UsbDeviceConnectionJNI com.example.meterreader D close
Anyone, please check my code…
Anyone, please check my code and suggest what is wrong with it.
