  2. DLMS Meter Gurux DLMS Director Properties
By JoshuaStar, 8 December, 2025
I have EM101+ DLMS Cat C3 IS15959 Meter, Lauritz and Knudsen.
I'm Reading the meter through DLMS Director.
1. What are the config properties ?
2. Like What manufacturer should be selected? Indian Standards or L&T?
3. what should be the interface ? HDLC or Wrapper or what ?
4. what should be the client, logical, server, physical addresses ?
5. what baud rate should be set ?
6. What about authentication ?
7. To read clock do i require a password?
1 month 1 week ago
Hi, The DLMS standards don't…
The DLMS standards don't define the settings, and they can be anything.
Try with Indian Standards. WRAPPER is for TCP/IP connections and HDLC is for setial port connections.
Try with the default client and server addresses.
Baud rate can be anything. You need to test it. Start it from 9600.
Try to connect without authentication first to make sure that your settings are correct.
  • Tue, 01/20/2026 - 10:38
    gurux.dlms.java 4.0.89
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Mon, 12/15/2025 - 08:11
    Gurux.DLMS.Net 4.0.87
  • Fri, 12/12/2025 - 08:38
    Gurux.DLMS.Python 1.0.195
  • Generic Profile- gxGet with selector=2: different behaviour on cpp and cimplementation
  • DLMS Client–Server Communication Over GPRS Fails With Dynamic IP
  • Pre-established connection questions
  • writing Error "Service not allowed"
  • High GMAC meters can’t authenticate – can’t read invocation counter
