  2. Using MAX3232 + FT232RL To Energy Meter With GXDLMS Director
Using MAX3232 + FT232RL to Energy meter with GXDLMS Director
By JoshuaStar, 7 December, 2025
I want to read an energy meter using its RS232 port with GXDLMS Director.
The meter I am using is L&T EM101+ DLMS Cat C3 IS15959.
I do not have a RS232-to-USB cable with a DB9 connector right now. I have a MAX3232 RS232-to-TTL converter and an FT232RL USB-to-TTL module.
My idea is:
Meter (RS232) → MAX3232 → TTL → FT232RL → USB → GXDLMS Director
Will this work?
Can I convert RS232 to TTL using the MAX3232, then convert TTL to USB using the FT232RL, and read the meter normally with GXDLMS Director?
This is the FT232RL USB-TTL module I have:
https://www.ktron.in/product/ft232rl-usb-to-uart-ttl-module-5v-3-3v/?ut…
And this is the MAX3232 module:
https://quartzcomponents.com/products/max3232-rs232-to-ttl-serial-port-…
I know that a simple RS232-to-USB converter cable would work and it is cheap, but I don’t have one at the moment. I also want to try this setup out of curiosity.
Please let me know if this setup is OK and if there are any special settings I should use.
Thank you.
1 month 1 week ago
Hi, Please, buy the ready…
Please, buy the ready cable. Cables are causing so many problems. It will save so much of your time.
  • Tue, 01/20/2026 - 10:38
    gurux.dlms.java 4.0.89
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Mon, 12/15/2025 - 08:11
    Gurux.DLMS.Net 4.0.87
  • Fri, 12/12/2025 - 08:38
    Gurux.DLMS.Python 1.0.195
  • Generic Profile- gxGet with selector=2: different behaviour on cpp and cimplementation
  • DLMS Client–Server Communication Over GPRS Fails With Dynamic IP
  • Pre-established connection questions
  • writing Error "Service not allowed"
  • High GMAC meters can’t authenticate – can’t read invocation counter
