  2. Confirmed Push Service Support
Confirmed push service support
By Jayaraj, 2 December, 2025
Hi, Does Director support confirmed push service support to enable acknowledgement for received push messages?
Jayaraj
4 months 2 weeks ago
Hi, ACK generation is…
ACK generation is implemented in C#, which our customers are using, but
GXDLMSDirector doesn't support ACK for push messages. The reason for this is that most of the meters do not use ACK, and there is no way to determine whether it should send or not.
Jayaraj
Hi Mikko, I was just…
I was just referring to green book, which says tag 16 is for confirmed push, that should help to decide response with Ack right?
-- data-notification
data-notification [15] IMPLICIT Data-Notification,
data-notification-confirm [16] IMPLICIT Data-Notification-Confirm,
Hi Jayaraj, My bad. I…
Hi Jayaraj,
My bad. I remember wrong, and you are right. There is a own message type for the acknowledgement push message.
  • Tue, 04/14/2026 - 11:47
    gurux.dlms.java 4.0.93
  • Mon, 04/13/2026 - 16:12
    gurux.dlms.java 4.0.92
  • Mon, 04/13/2026 - 11:39
    Gurux.DLMS.Net 9.0.2604.1301
  • Tue, 04/07/2026 - 17:17
    Gurux.DLMS.Python 1.0.197
  • Tue, 04/07/2026 - 15:03
    gurux.dlms.c 9.0.2604.0701
  • FRMR information field translation
  • Connect to EDMI metter
  • Meter rejects reading multiple objects, but it conformance says it supports it.
  • ISKRA ME372 CONNECTION BY DLMSDIRECTOR
