  2. Insufficient Memory To Continue The Execution of The Program.
Insufficient memory to continue the execution of the program.
By Idea@1234, 29 October, 2025
Dear Gurux Team,
I am facing an issue while attempting to update the firmware on a meter, and I need your assistance in resolving this. Below are the details of the error I'm encountering:
Error Message: Failed to update meter firmware.
Error Details: Insufficient memory to continue the execution of the program.
Logical Name: Not specified in the error.
Steps Taken:
I tried updating the firmware using the standard procedure.
The error occurred during the firmware update process, and it was accompanied by the message “Insufficient memory to continue the execution of the program.”
I've confirmed that the meter's hardware is in working condition and there are no physical faults.
Additional Information:
Operating System: Windows
Could you please help me understand the cause of this issue and suggest possible solutions or workarounds?
Idea@1234
1 week 4 days ago
"Failed to update meter…
"Failed to update meter firmware" - Insufficient memory error
1 week 4 days ago
Hi, The meter returns an…
The meter returns an invalid reply. Updating the firmware changes between the meters.
Try to first read the Image transfer enabled attribute and check that it's set.
https://gurux.fi/Gurux.DLMS.Objects.GXDLMSImageTransfer
Idea@1234
1 week 4 days ago
Hello thank you for your…
Hello thank you for your time,
The image transfer has been enabled in the code level and followed all the procedures mentioned in the GURUX catalog to update image.
For one of the meter i'am facing the issue , when i tried to contact with the manufacturer they suggested to reboot the meter .After reboot the meter is actively taking the update.
Is it the only solution?.
4 days 23 hours ago
Hi, The meters usually…
The meters usually reboot when you activate the new image.
Meter manufacturers have implemented this differently, and I am not aware of how your meter manufacturer has implemented it.
  • Wed, 10/29/2025 - 08:51
    gurux.dlms.c 9.0.2510.2901
  • Thu, 10/16/2025 - 09:59
    gurux.dlms.java 4.0.83
  • Wed, 10/08/2025 - 10:21
    gurux.dlms.c 9.0.2510.0801
  • Fri, 09/26/2025 - 10:02
    gurux.dlms.cpp 9.0.2509.2601
  • Fri, 09/26/2025 - 09:45
    gurux.dlms.c 9.0.2509.2601
  • Guidance on using the source codes
  • How to get/convert user readable format data from readRowsByRange
  • Insufficient memory to continue the execution of the program.
  • The client instance code failed to connect to the electricity meter for authentication
  • Unable to Release Request when closing connection with meter.
