  2. Regarding The Dlms Android Project
Regarding the dlms android project
By atuldd, 27 October, 2025
Gurux DLMS for Android
I am working in a project where need to communicate with NON DLMS meters that use the IEC 62056-21
Is it possible if Gurux serial can be used to handle the communication
4 months 1 week ago
Hi, Yes, you can use Gurux…
Yes, you can use Gurux Serial. You just need to set the correct serial port settings.
atuldd
4 months ago
Hi Mikko, Can we use…
Can we use GXDLMSDirector or Gurux DLMS library to communicate with non-DLMS meters that follow the IEC 62056-21 protocol?
The reason I ask is that the request and response format in non-DLMS IEC 62056-21 meters is different from DLMS meters.
Also, is it possible to communicate with such non-DLMS meters from an Android application using Gurux libraries?
4 months ago
Hi, No, you can't. DLMS and …
No, you can't. DLMS and IEC 62056-21 are two totally different protocols.
You can get more information by reading: IEC 62056-21 is not DLMS/COSEM:
https://gurux.fi/DLMSCOSEMFAQ
  • Thu, 02/19/2026 - 11:51
    gurux.dlms.cpp 9.0.2602.1901
  • Sun, 02/01/2026 - 19:47
    gurux.dlms.cpp 9.0.2602.0101
  • Tue, 01/20/2026 - 10:38
    gurux.dlms.java 4.0.89
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Gurux C library DLMS book edition support
  • Help with connection and read with landis+gyr e650 + CU-E22 using python
  • Preestablished connection
  • RJ11 to RS232 Pin out SECURE Premier 300
  • GENUS sugam 3 PH bidirectional
