  2. Physical Addres
Physical addres
By ksk, 21 October, 2025
Hi.
I have a device with a physical address of 6538. I'm setting this address in GURUXDirector. But in the command line parameters, this address looks like "-s 22922" What's the formula for converting 6538 to 22922?
1 month 1 week ago
Hi, What meter do you try to…
What meter do you try to read? I believe that you are using a serial number where the address is counted from the serial number, and you don't give the direct physical address. Is that the case?
  • Tue, 12/02/2025 - 10:21
    gurux.dlms.c 9.0.2512.0201
  • Mon, 12/01/2025 - 13:55
    Gurux.DLMS.Python 1.0.193
  • Thu, 11/13/2025 - 15:23
    Gurux.DLMS.Python 1.0.192
  • Thu, 11/13/2025 - 14:55
    gurux.dlms.java 4.0.84
  • Wed, 10/29/2025 - 08:51
    gurux.dlms.c 9.0.2510.2901
  • SNRM byte mening
